Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-21-2004, 04:39 PM
SenseiAccord SenseiAccord is offline
Floating RPMs
I had no other way of stating my problem so im just gonna call it floating RPMs. Ok my problem is on a 90 accord EX. When im moving and changing gears i noticed that when i press the clutch in to change gears my RPMs float for about 1-2 secs then dropping instead of dropping instantly. Sometimes it rises 100-300 RPMs depending on my engine speed when changing gears. I have a feeling the problem is coming from the clutch/flywheel area cuz my thottle body is working properly and usually when im about to accelerate in first i hear this weird squealing sound of some type that is pretty loud and embarassing. Can you guys please help me as much as possible? thanx ppl!
Old 02-21-2004, 08:36 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
does it do this in other manual cars that you've driven? could be sticky feet on the gas pedal while pressing the clutch.
Old 02-21-2004, 10:03 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
it could be your throw out bearing not disengaging properly after contacting the clutch, like its getting stuck, then releasing on its own.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-22-2004, 04:25 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Floating RPMs
Either one of those sounds perfectly resonable to me.
Old 02-22-2004, 04:43 AM
FDTT FDTT is offline
Re: Floating RPMs
When you press in your clutch the RPM's increase? Then it is not your clutch, disengaging your clutch will not cause the car to rev higher. You pedal assembly may be jaming, or your clutch pedal may as well. Clean them off with brake clean and re lube them see if that helps.
If it were just still maintaning rpm with no change for a few seconds then i may suspect the clutch, but i dont think that is it. Cause you mentioned that it increases rpm on some ocasions. But i could be wrong. Good luck with that
Dont drive faster than your angels can fly
Old 02-22-2004, 11:33 PM
Re: Floating RPMs
I dont think im that bad of a driver. I used to drive my truck (that was 5 spd) and it never did that. Also the first week i got my car i started to notice it and thought all cars (not trucks) did it and firgured it was normal until i started to think that that did make sense. So i test drove my friends teg (5 spd) and it didnt do that. Cant be my driving cuz i driven 3 cars (5 spd) including my are and only mines did that.
What FDTT said about the pedal assembly could be a possibility cuz my clutch pedal sticks out a little further than my break pedal. I thought the brake and the clutch pedal are usually at the same height. Since my RPMs does rev a little more occasionally i guess the my gas pedal could be getting jamed. Where in the car should i try using the brake cleaner on? Inside or engine bay area? Dont really know where these locations are usually located. By the way thanx for the good luck FDTT! hopefully that luck comes into play
Old 02-23-2004, 12:07 AM
Re: Floating RPMs
No problem.
For the brake cleaner, look in your footwell and clean off the hindge points of the pedals, use a bit of brake cleaner, a rag and maby even an old tooth brush. Get them good and clean then use some grease or other lube to lubricate the hindge points.
Also you may want to try to find the throttle cable assembly, check to see if there are any kinks in the cable that may cause it to get stuck, if there are none spray some lube down the cabel and push the gas pedal. Repeat this a few times, do the same with the other cables too (just for a service). And then see if it happenes again.
hope that helps.
