Old 02-21-2004, 02:46 PM
sbddude sbddude is offline
AF Premium User
sound cuts out on pioneer deck
I have a pioneer 4500MP and when i first start the car it works fine. Then a little while later the sound completely stops; all speakers have no sound: no static or anything. I have to leave the car off for a while to get the sound back. What is causing this?
I have 2-way 4-ohm speakers in front and 8-ohm woofers in back.
Any help is appreicated!
Old 02-21-2004, 03:37 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: sound cuts out on pioneer deck
sounds like it's overheating
how loud do you have it playing when this happens?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-21-2004, 08:28 PM
AF Premium User
not very loud at all. It happens within a minute of starting the car after sitting overnight.
Old 02-22-2004, 12:11 AM
sr20de4evr's Avatar
when the sound cuts out, does the headunit stay on and keep playing or does it turn off?
'01 Black Sentra SE
'05 Silver WRX STi
Old 02-22-2004, 12:28 AM
AF Premium User
no, it stays on....i can load cds, change radio stations, ect
Old 03-02-2004, 09:00 PM
AF Premium User
any advice, anyone??
Old 11-16-2004, 01:34 PM
cmaleska cmaleska is offline
I have the same HU and the same problem
I just replaced the deck with the same model and still have the problem could you let me know if you find the solution
Old 11-16-2004, 01:38 PM
AF Premium User
I solved the problem. One of my speakers had a loose connection in the door. It may have been shorting. Check all your speaker wires to make sure everything is wired right. Also check fused both in the cabin and under the hood.
Old 11-16-2004, 06:53 PM
Thanks ill check them
