Old 02-21-2004, 02:07 PM
newcivNC newcivNC is offline
Help removing console '99 GranPrix
Have read all excellant posts about gear stuck in park and unable to remove key. I've got the same problem. I'm trying to remove the console on my '99 GranPrix. I've removed 2 bolts in center well, 4 bolts and plate at half-mast. The console still won't come free. Am I missing additional bolts under the ashtray? How will the console slip over the gear stick?
Thanks very much for any assistance/information!!
-Jeffrey
Old 02-23-2004, 07:54 PM
rockford0384's Avatar
rockford0384 rockford0384 is offline
Re: Help removing console '99 GranPrix
Okay Im taking it as if you removed the bolts that are in the center consule under the holder thing. (where you can put things, under that) If im right you need to take to top piece off to get to the other bolts holding the center consule in place. Lift up on the top piece starting where you removed the holder for your stuff. Work you way down the piece theres like 10 tabs holding it in, there pretty strong. Wiggle it around to get out.
heres the top piece im talking about
After that I dont know what to do... Havent removed mine yet. Good luck.
hope that helps you out, if were talking about the same part
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver,
still trying to figure out how that happened
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 02-24-2004, 01:37 AM
amac209 amac209 is offline
Send a message via MSN to amac209
theres a clip holding the shifter knob on it's like a really long staple should be near the bottom pointing of the knob. pry it out with a small screwdriver or pick then the handle should pull straight off.
