Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 02-21-2004, 12:12 PM
gangaware gangaware is offline
radio (probably fuse)
I have a 1992 jetta. I installed a kenwood radio/cd deck 2 months ago. the system worked fine until last night. the deck doesn't seem to have any power. i had the deck checked by the store, it is fine. i found the fuse box but there are 21 fuses. any idea which fuse is for the radio or how i can locate the correct fuse?
thanks!
Old 02-21-2004, 07:39 PM
boschmann boschmann is offline
Re: radio (probably fuse)
My info says it's on fuse 22, are you sure you only have 21? On some of the later models there is a hidden fuse holder that powers the radio & lighter above the main fuse panel.
Old 02-22-2004, 05:14 AM
we counted and there are 21 however, we will search for a "hidden" fuse holder above the fuse panel! the jetta is a 92. thanks for your information, we will give it a try!!!
Old 02-24-2004, 03:53 AM
we changed the fuse, but the stereo and lighter still don't work. any thoughts on what we should look at next?
Old 02-25-2004, 05:47 PM
Use a test light or multimeter to verify there is 12V at the fuse & radio, power to fuse comes through ignition switch. If so, check the brown wire is grounded, connects to ground near fuse panel
