Old 02-21-2004, 09:38 AM
JOnEB4EvR JOnEB4EvR is offline
Send a message via Yahoo to JOnEB4EvR
E-Brake lamp stays on...
anyone know how to fix it?!
I've already checked to make sure that the little button is pressed. I've even pressed it down manually and the light STILL stays on. Is there something else that I need to check out? Anyone know how the switch works? I don't see any kind of two metals touching that might complete the circuit if there's supposed to be one. Except for maybe the casing of the button. Let me take a pic here, and I'll post what it looks like if ya'll don't know. year/model of car is in the sig.
2003 Ford Focus ZTS
Old 02-21-2004, 10:37 AM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: E-Brake lamp stays on...
pull the wires off of the switch and see if it still stays on, if it goes out then replace the switch. if it stays on then you probably have a bad relay somewhere...sorry, i dont know the car that well to tell you where to look..
Old 02-21-2004, 11:04 AM
here are a couple pics... one with the e-brake on and one off
2003 Ford Focus ZTS
Old 02-21-2004, 11:06 AM
yea, i forgot to mention that... i pulled the switch and the light stays on... so where's the relay?
2003 Ford Focus ZTS
Old 02-21-2004, 11:53 PM
Since there is one wire on the switch it makes a ground ..use a volt meter and determine if there is power present on the wire..take a jumper and ground the wire and see if the light goes off.. You will have to look in the service manual to get the wiring diagram and see if there is a relay in the system. If there is not then its most likely a groung fault..
Old 02-22-2004, 12:09 AM
ok, i'll check it out tomorrow... thanks
gotta buy a multimeter :P
2003 Ford Focus ZTS
Old 02-22-2004, 12:28 AM
Nalfein Nalfein is offline
I don't know about all that electronic stuff you guys are talking about... but I had the same problem a while back. Turns out I was staying on because my rear brake pads were so worn that the sensor was messing up. Put on new rear pads and problem fixed.
Might not be that simple for you but goodluck anyhow
