Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 02-21-2004, 07:00 AM
llindsey44 llindsey44 is offline
gas odor
I have a 94 LHS that smells of gas odor after running, there is no leak and no fuel loss , the fuel rail has been replaced under recall last year, I have also lost pressure in the fuel tank, when i open the fuel cap there is no pressure, I have replaced the fuel cap to no avail, replaced the carbon filter, can anyone please tell me what is going on???
please email me at [email protected]
Old 04-17-2004, 10:40 PM
jhndeeregreen jhndeeregreen is offline
Re: gas odor
did you fiquire it out becuase i also have a lhs that i have an gas oder that is unexplained?
Old 04-26-2004, 01:49 PM
golfguy10 golfguy10 is offline
Same issue
I'm taking my car in tomorrow to have it checked. It's a 1997 LHS - I did check my spark plugs and the spark plug port was full of oil. I had the gasket repleced before and I guess need it done again. I'll let you know what my mechanic finds out.
Old 09-04-2004, 02:21 AM
AWP9521 AWP9521 is offline
Had that same problem on my 94 LHS, turned out to be the Fuel Injector O-Rings needed replaced, It's kind of hard to see the leakage as the Intake Plenum covers up the Injectors a bit but that was what needed to be done on mine. If you replace the O-Rings yourself, BE VERY CAREFUL! The the injectors are mounted in Fuel Rail made of a plastic type material and can be broken or cracked fairly easily. Also the Injectors are a bear to remove because the O-Rings will litterally glue themselves to the Fuel Rail. If your not mechanically inclined then I would highly recommend having the Dealer replace them.
