Old 02-21-2004, 02:49 AM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
smoke from valve cover breather
when i turn on the enigne, there is a lot of smoke that comes out from the breather, it looks like my car is blown up why is it doing that? and the timing is right, but the valve adjustment is wrong, will the piston damage the valve still?
Old 02-21-2004, 04:01 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: smoke from valve cover breather
Ok so you replaced the head gasket recontly right. If not what was the last thing you did to the motor before this happened.
Old 02-21-2004, 07:32 PM
yea, i just replaced the head gasket, and it looks like the breather is a 2nd exhasut.
Old 02-21-2004, 07:34 PM
oh, and i adjusted the valves, i think i did it right .08mm on the intake valves and .15mm on the exhaust. and the timing is right on the red mark on the crank.
Old 02-21-2004, 07:50 PM
Bronco2 Bronco2 is offline
Excessive crankcase pressure is caused by 2 things-a non functioning PCV system or compression leakage by the piston rings.
Old 02-21-2004, 10:23 PM
ill check the pcv valve, i broke it when i changed the head and i got a new one. how do i check if its broken or not?
Old 02-21-2004, 11:12 PM
whtteg's Avatar
Take a pair of pliars and gentley pinch the hose that connects to it and see if you hear a click noise, if no nosie then it is likely bad. Remove it and shake it back and forth and see if you hear a ball moving inside, if not then it is deffinatly bad.
Old 02-21-2004, 11:36 PM
the pcv valve is ok, can i just take a hose and t the pcv line and plug it in there?
