Old 02-20-2004, 10:24 PM
mannpeg729 mannpeg729 is offline
94 BUick Lesabre
Help! My 94 Buick Lesabre started having an issue with the A/C and heat. sometimes the buttons on the heater will not work. if you push the button it stays stuck on whatever setting it is on. we have had a diagnostic computer check that is showing an electric issue but not what specifically is having a problem. anyone ever heard of this?
also, the car is choking a little. someone said it's probably the catalitic converter. what do you think?
Old 02-23-2004, 01:21 PM
RABarrett RABarrett is offline
Re: 94 BUick Lesabre
Check you fuel pressure. Typically, as the pump ages, the pressure drops, causing the computer to add fuel to the mixtures to compensate. Ray.
Old 05-15-2004, 10:14 PM
jerzy jerzy is offline
Same car same problem with A/C vent controls etc.......I have just started to work on it and beleive that the vent control module is bad.....if you figure it out first, let me know!
I will do the same.
Old 05-24-2004, 09:01 PM
508gm1 508gm1 is offline
I have also had a problem with my 1994 custom climate control unit. On occasion, the unit will just go off, then about a minute later, it resets to defrost. This is most annoying on hot summer days!!! I've only had the car for 5 months, but its only got 116,500km (bout 72mi). The cars hardly broken in!!!
anyone who could help, i'd appreciate it.
The joys of a Buick climate and electrical system
