Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-20-2004, 08:05 PM
Creepingdeath Creepingdeath is offline
Removing 02 Censor
When I got my intake and headers installed, they disingaged the 02 censor which made my car MUCH faster. I took it back to get fixed cuz i have to get the car smogged in the next week. What I was wondering, is after I smog it should I take it off again. Is this bad for the engine. Could someone explain why it makes it faster? Thx
Stealing a quote from one person is Plagurism....
Stealing a quote from many people is research!
Old 02-20-2004, 09:35 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Re: Removing 02 Censor
taking out your O2 sensor should in no way make your car faster or increase your horsepower... all it is is a sensor.... it just measures the exhaust fumes...
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 02-21-2004, 12:00 PM
tegboi's Avatar
tegboi tegboi is offline
Send a message via AIM to tegboi
02 sensors can change ur mixture of air and fuel. it might just have you run a bit richer. have u noticed any mpg drop?
Team Ultraspeed - CA, Bay Area
18.m.510
1990 integra LS - awake & roaring
1991 integra GS - in the grave for parts in the back..
1992 integra GS-R - workin on it - awake & roaring also
1990 LS auto-manual conversion - complete
deciding between a 1990 civic EF or a 1993 civic EG
Old 02-21-2004, 01:37 PM
I did not drive it enough to notice the mpg drop. I'm guessing it ran richer, but how much of an effect would it have on the mpg? and would it be worth it. If it has a big effect, I can leave it on, then when I go racing remove it again. This would prolly be the smartest idea. However, does it always run rich? or could it run dry? Any info is help
Old 02-21-2004, 02:59 PM
tegboi's Avatar
im not fully sure on how it works at all times. but the 02 sensor starts a open loop, then later when the car warms up, it runs on a closed loop that is remembered in the ecu. but you also loose air through the 02 sensor bung. ur better off keeping it on, and upgrading parts under the hood..
18.m.510
Old 02-21-2004, 03:46 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Put it back on there are a few things that will happen to the motor if you don't, 1 the motor will fall into limp mode when it goes into closed loop and 2 the motor will be running way rich and you will not be able to rev over 3.5K rpm. Also the motor running rich will wash the cylinder walls with gas.
Old 02-21-2004, 06:25 PM
tegboi's Avatar
and you dont want that..
18.m.510
Old 02-21-2004, 06:28 PM
thx a grip Whtteg. I was kinda guessing there was a downside to it other the mpg. I'll make sure not to do that again
Old 02-21-2004, 06:53 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
ya when my o2 sensor was broke i was running way rich and lost about 3 tenths of my 1/4
civ eg hb/b18c1
PT61 .68ar p-trim
Full-race pro street manifold
Neptune EMS
412whp@10psi 11.62@118
633whp@28psi 10.45@135
