99 Caravan - replacing headlamps?
Help! My passenger side front headlight is burned out. Hi-beam works as do parking lights and turn signals. Do I have to replace the entire assembly (w/o quads?) - it's one bulb - any suggestions?
I did find the assembly online for $107 including shipping - next cheapest price I found was $185 plus shipping. But, I can't find any place that has instructions on how to disassemble and reassemble. Anyone? TIA!!! C. |
Re: 99 Caravan - replacing headlamps?
no way all you need is the replacement bulb right in front of the washer fluid jug youll see the bulb now follow the wires to the bulb and now twist the black plastic holder towards the driver side and it will come of now you see the bulb socket just pull away from you to change the bulb its simple once youve done it once itll take 5 mins max the next time ,also every single light on your van just needs a bulb replacement
oh ya i forgot dont touch the glass on the bulb and it should cost about 10$
If you look in the front wheel wells you'll see two removeable caps one on each side. Remove the cap reach inside you find the bulb housing. it is a tight squeeze if you have big hands. the easiest way is to remove the three or four nuts from the headlight housing slide the headlight out replace from there very easy to do. had to do it on mine a few times. good luck.
sorry wrong bulb replacement my post was for signal light replacement. read your post wrong.
