Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-20-2004, 12:34 AM
SenseiAccord SenseiAccord is offline
Speed govern
how do u remove this from the ECU or the ECM or whatever it is hooked up to? I hear if u remove it then u can unlock some good power. Is there a way to remove it or do u just gotta buy an aftermarket computer chip? By the way i got a 90 accord ex
Old 02-22-2004, 09:47 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I believe that the governers are built into the ECU (correct me if i'm wrong). If this is the case, the only thing you could do is change the ECU, or get it reprogrammed. Getting this done wouldn't really free up any power (it may make the motor rev higher, but that is a bad thing for long term use). All it would do is let you go faster, and most cars go fast enough already; roads aren't meant to be going 150mph on.
Old 02-25-2004, 12:29 PM
ghost94 ghost94 is offline
Send a message via AIM to ghost94
Re: Speed govern
Come on 138 is not nearly fast enough for a GSR
keeps pulling its got more
any ways who says we'll do it on the roads
"Smokin to prevent Glaucoma....." -someone like me
my lil gsr-civic turbo gon'b fas dawg
MOTOR OTHER TOYS FOR SALE
Old 03-08-2004, 09:37 PM
lumen lumen is offline
disclaimer: it is illegal to disable a speed governer on a car... state laws may vary, but this a rather universal law.
regarding how to bypass it, you will need to buy an aftermarket ECU.
only if you are extremely skilled with electronics would I dare you to try and make changes to your current ecu on your own.....
personally, I gave up my attempt at manipulating my '85 ECU, and I figured it would be relatively simple (yours I might note is 5 years newer)... keep in mind, that I am an engineering major (undecided), and my father who was helping me is an electrical engineer.
don't mess with what you don't understand
Old 03-08-2004, 10:26 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
don't post in threads that are a month old
Old 03-09-2004, 12:34 PM
drklver's Avatar
drklver drklver is offline
Send a message via AIM to drklver
Re: Speed govern
you did!
08 express hi speed governer too low justav6 Express | G Van 2 01-21-2008 09:22 AM
RE:How to disable the speed governer/limiter? 03yellocavi Performance 1 02-27-2005 01:38 PM
How to disable the speed governer/limiter? Classicrocjunkie Performance 52 02-26-2005 11:19 PM
