Old 02-19-2004, 07:09 PM
jonp672 jonp672 is offline
1999 silverado compass calibration
I have a 1999 silverado the compass has an o/c100 on it, if i push the compass button it goes through numbers 1 tru 15 and thats it. Any one have the information availible to re program the compass? If so please post it or email it to me at [email protected] thanks JonP
Old 02-20-2004, 12:25 AM
bans25 bans25 is offline
Re: 1999 silverado compass calibration
what location do you need it set for? where are you?
Old 02-20-2004, 05:32 AM
anderson, indiana 46011
Old 02-22-2004, 10:50 PM
Imkunfused Imkunfused is offline
you should use number 7 or 8
Old 02-23-2004, 03:51 AM
ok 7 or 8 so i set it to that then what? just let it sit on 7 or 8 or is there some sequence or button that i hit to make it enter?
Old 02-23-2004, 11:03 AM
I believe thats all you have to do. Also if it comes up and says CAL on it.. You need to drive around in circles, 5-9 mph until it goes away.. No im not kidding either.. Its a way for the Mirror to calibrate itself
Old 02-23-2004, 09:16 PM
skull skull is offline
The last response is correct except the 7 or 8 which may or may not be where you live. These numbers are to compensate the variance in true magnetic north. The zones span in North America from 1 to 14 like a fan, origin of the fan is around the north pole. 1 is in the Alaska area, 14 is in eastern canada. The US spans from 3 (Washington) to 13 (Maine). 7 or 8 is central-east US.
Tell me where you live and I'll tell you what zone to use.
Old 02-25-2004, 04:30 PM
He lives in indiana.. I looked at my owners manual, and part of indiana is in 7, and part in 8.
Old 02-25-2004, 08:45 PM
home
I live in anderson indiana, 46011 Madison County 20 miles north of indianapolis. Unforunitly I moved and my owners manual is in a box somewhere
Old 08-13-2004, 05:15 PM
95ragtop 95ragtop is offline
IF the above postings didn't work there may be a reason the display reads 188%CF. There is a wire harness that goes from inside the mirror to a housing at the mounting base of the mirror that may be unplugged or broken. I had one do this. It was tough popping the two halves of the mirror apart (be carefull), but once I plugged it back in, it worked great. Good Luck.
