Old 02-19-2004, 03:37 PM
putz65 putz65 is offline
Question 97 t&c keyless entry
I have a 97 t&c AWD that has a factory keyless entry. I have tried to install a remote car starter that has keyless entry but havent gotten that to work properly. If anyone knows how to hook this up properly or if there is some kind of kit to do this I would like the help. If you could program the remote start to work the factory keyles entry that would work also.
Old 02-20-2004, 06:56 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: 97 t&c keyless entry
WOW, I am impressed that you have gotten this far without messing up the BCM of the van!!! This is one of the most difficult of vehicles to do the remote start on.
Anyway, the locks is a one wire system. It should be a white/green wire. It is located in the left plug at bottom of fuse panel. Use relays and set up for negative trigger. Place a 4020 ohm resistor inline on the lock output, and a 665 ohm resistor inline on the unlock output. If you do not have a factory security system use a 1500 ohm for lock and a 250 ohm for unlock.
Old 08-15-2006, 08:59 AM
onerchprk onerchprk is offline
Send a message via MSN to onerchprk Send a message via Yahoo to onerchprk
Does the wire have to be split in two for the lock/unlock on the aftermarket Remote Start/Keyless entry?I have a Bulldog RS114 Remote system...
1997 Aerostar (239,000 Miles)
1993 Aerostar (189,000 Miles)
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
