Old 02-19-2004, 09:01 AM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
KYB Gas adjust rear shocks...98gt Quad ????
I noticed my drivers side rear was a bit lower than the passenger side the other day and found out my shock was bad...almost 1/2in lower than the other one.
So I called Summit and ordered some KYB gas adjust shocks....the 2 shocks and the Quad shocks......now the quad shocks are full shocks .
My stock quads have an "open boot" at one end, but the KYb's have a sleeve on both ends??? I looks like theres not enough clearance between the 2 to fit without them rubbing together??
Does one end of the KYB quad come off to allow for clearance???
Old 02-19-2004, 04:05 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: KYB Gas adjust rear shocks...98gt Quad ????
Quad shocks are mounted horizontal. Regular rear shocks are mounted vertial. Maybe you got the wrong ones, cause quad shocks won't make a difference on how your car sits height wise.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-19-2004, 08:33 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Hey highflow, do you run your quads yet? How important are they really. All they do pretty much is to help out the rear shocks with stability right?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-19-2004, 10:04 PM
HiFlow5 0's Avatar
Stanger
I still have quad shocks. They help with axle twist, mainly with the stock bushings and control arms. When I finally get my suspension set up correctly, I'll remove the quads all togther.
-2013 Ford Flex
-1999 Ford F150
Old 02-20-2004, 07:42 AM
DDMTK421DS's Avatar
Re: Re: KYB Gas adjust rear shocks...98gt Quad ????
Yeah I know that. I am sorry, I mislead you, the quads I got are smaller that the regular shocks. I was just worried about the fact that they are different than my stock quads. I found an install help page at KYB.com.
It says to use the spacers provided in the box (they are there) for my 98year model. I will call the summit tech line today and ask.....
