Old 02-19-2004, 04:27 AM
viridion viridion is offline
Send a message via ICQ to viridion Send a message via AIM to viridion Send a message via MSN to viridion Send a message via Yahoo to viridion
stubborn crank bolt
well i been workin on my LS swap all night and i can't get the bolt off the crank to get the pulley off and such... i know the torque specs are high but i've broken 2 half inch sockets, a reducer, a half inch breaker bar and nearly my neck
any tricks to getting that bolt out?
i figured i should put a new timing belt on the motor before i put it in the car..
i was just going to cut the timing belt cover apart and slip the belt behind the pulley but i realized the timing mark is on the cover
it is lefty loosey right? i been using a half inch breakerbar with a 4 foot pipe on the end but i keep breakin stuff
good thing the snapon man comes once a week
Old 02-19-2004, 06:00 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: stubborn crank bolt
You're in good company, the most common solution is to use a strong impact wrench and impact socket. You're correct, it's lefty loosey. Let us know what happens. GL
Old 02-19-2004, 09:16 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Yeah, the only good way to get those off is with an impact. Some morons like to put locktite on those as well, and you may be in one of those situations.
As for breaking sockets...buy something like craftsman or snap-on/mac, never have to worry about breaking those, because you get a new one free. I use craftsman normal sockets with impact and I have never broken one.
Old 02-19-2004, 10:04 AM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
I used lots of PB-Blaster, a 6 foot metal pipe, and some cheapo socket. Came off the first time I put all my weight on the end of the metal pipe.
DOHC ZC 89 DX HATCH
Old 02-19-2004, 03:51 PM
all i use is snapon stuff hehe.. and it keeps breakin.. i gotta wait now til i can get it replaced... that's tomorrow tho.. i don't think my impact can get it off cause it's only 180psi and my weight on 6 foot of leverage is a bit more torque than that.. i'll try her out tho
thx guys i'll keep sprayin the WD40 on it and wrenchin away
Old 02-19-2004, 05:56 PM
91B16Civic 91B16Civic is offline
alright well this is what me and my friend did to get mine off. alright..
1) put the car in gear
2) put a person in the driver's seat and have them hold the brake pedal with everything they have
3) put on your 1/2" breaker bar and socket
4) attach your 4' pipe
5) hold end of pipe and crank on it with everything you have.
we were bowing a 1/2" breaker bar pretty good before the sucker snapped loose and trust me when it breaks free it feels and sounds like you just broke the car. But it worked.
or alternative solution
1" drive impact
Old 02-19-2004, 06:33 PM
hitr99 hitr99 is offline
yea, but an impact gun also uses vibrations to loosen stuff up
Old 02-19-2004, 06:52 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
hah hah broken sockets, eh?
Those are two seperate extention bars i broke working on my car.....unfourtunately they were brand x and there was no warranty...Just one more reason to buy craftsman!
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-19-2004, 08:47 PM
i took that just before i broke the bar
Old 02-19-2004, 09:29 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
to get mine off, I bolted an 8foot pipe to the transmission end of the crank shaft, and then used a 3foot breaker bar with a 3 foot pipe over the end of that... my friend was standing on the end of the 8ft pipe while I worked the breaker bar.... barely took any effort at all with all that done
Honda Enthusiast
Old 02-19-2004, 10:17 PM
lilol89crx lilol89crx is offline
3/4" impact gun(1000ft lbs tq rev) 150psi out of 75 gal compressor, pull the trigger and thats all to it :P
Old 02-19-2004, 10:46 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
breaker bars are wimpy and impact wrenches are for fags whip out the torch
Old 02-19-2004, 11:21 PM
Killa_CRX's Avatar
When Civics Attack!
Re: Re: stubborn crank bolt
Heating the metal with a torch damages and weakens it.
Don't believe it? Take a sewing needle and a match... first try bending the needle... then heat the needle with the match (or lighter, whatever you prefer) until the end is good and hot (shouldn't take too long)... then try to bend the needle again. You'll notice that it bends with nearly no effort, and if you bent it fast, it would almost shatter off at the end... Now imagine that happening to your crank inside the engine at some odd thousands of rpm's.
Honda Enthusiast
Old 02-20-2004, 11:47 AM
dude with that setup it should break free.. just keep cranking on it..
Old 02-20-2004, 02:48 PM
i got that mo fackey.. took an 8 foot steel tube on the end of the breaker bar and a returned broken socket to napa hehe but i got it
all 300lbs of me on the end of that 8 foot handle
jumpin up and down and it finally broke.. made the most godaweful noise
and then i could get it off the rest of the way with my fingers
