Old 02-18-2004, 06:43 PM
fredthedragon's Avatar
fredthedragon fredthedragon is offline
Send a message via AIM to fredthedragon
jdm engine wear & oil questions
my old engine was eating oil, they never determined why, so i had it changed. i got a jdm reject engine it was supposed to be a duplicate replacement, however it came carberated, the shop i had install the engine switched it over for me, and said that i shouldn't see much of a difference. it was still slow as shit like i hadn't changed my engine, i was going to have it checked out by the shop, but then it started running a little better after a while. it also started eating a little oil, when i switched to a synthetic blend i got all my power back but i've burned half a quart in 5,000 miles between the oil change.
this may have been over kill to say the whole story but basically i was wondering if i should use some sort of product to recondition my engine and reduce the spaces between the seals or should i switch to higher mileage engine oil even though i'm only supposed to have 45k miles on it.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust.
current car: red 90-civic-STD-hb
with dx trannie, ecu, shift knob, & rear seats.
i hate my vynil seats.
p.s. i am once again with computer, please forgive the one year leave of absence.
Old 02-18-2004, 08:41 PM
travagliante's Avatar
travagliante travagliante is offline
Re: jdm engine wear & oil questions
It probaly has more miles on it than you think. Try changing oil, and more often. An you probaly need to get new piston rings. Just rebuild the engine and it will be like getting a brand new engine!!!
Old 02-18-2004, 11:48 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I have 262,000kms on my JDM B16A. The engine is not identical to the USDM ones at all - it runs a higher CR to produce 100ps. The twin-carbs would have been better than the FI you put on to make it US-legal.
I run full synthetic in my B16A and ran it in my twin-carb D15 (Aussie spec ED6). It got to 250,000kms until it ate oil - and the motor is identical to the JDM spec.
Sounds like you got ripped by either the importer or the guys that did the work
Get it rebuilt
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 02-19-2004, 08:02 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
You should try to find out where the oil is going.
Get a compression gauge (cheap item) and check your compression. If it's low, squirt a teaspoon of oil into each cylinder and try again. If it improves dramatically then it's your rings. You can try "Restore", it works great for worn rings.
If there is no change when you add the oil it's probably your valve guides and there are additives that will swell the seals to limit the oil burning.
These are all band-aids though, you will need a rebuild or head gasket eventually. Let us know how it turns out. GL
Old 02-22-2004, 01:58 PM
actually it might be due to the large amount of braking i use the clutch for.
Old 02-22-2004, 03:04 PM
Setanta's Avatar
huh?
I don't think so.
'99 PY DC2R
'85 BBS BMW E30
Old 02-27-2004, 08:27 PM
letting the engine do the breaking, sorry i may have not been so clear.
i would do that w/out using the brake petal it just seems that i go through engines quickly because my old engine went bad in a hurry too.
Check Engine Light & Oil Loss - 2000 Honda Accord Cpe giggles07 Accord/TSX/Accord Hybrid 5 04-22-2008 07:06 PM
Engine Rattling & Oil Leak 1995VaFordCrownVic Crown Victoria 5 09-14-2007 11:38 PM
2004 Dodge Intrepid Engine Light & Oil Light Maddiegirl2005 Intrepid 1 02-09-2006 11:03 PM
Regal engine rotation & other questions reddnekk Regal 13 06-17-2005 11:59 PM
JDM engine install on USDM questions Ricochet Engineering/ Technical 4 06-23-2003 11:48 AM
