Old 01-02-2002, 02:40 AM
Drunk_Monkey Drunk_Monkey is offline
Send a message via AIM to Drunk_Monkey Send a message via Yahoo to Drunk_Monkey
Cool 96 Accord Governer
On a recent road trip to Atlanta I had to pleasure of running into a couple of Integra's on the Freeway, anyways we all decided to push our cars a little and once my car hit 110 or so my governer kicked in and I was left in the dust by my new friends. Basically what im asking is does anybody know how to remove the governer?????????
Old 01-02-2002, 11:25 AM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
I too have a 96 LX and my governor kicked in at 110. You can get your ECU reprogrammed but you won't go that much faster if your tires and besides it isn't that cheap either to get a few more mph top speed.
EliteAccord at Import Love
Old 01-02-2002, 11:54 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
www.hondata.com
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 01-06-2002, 12:24 AM
JasonAccord98LX's Avatar
JasonAccord98LX JasonAccord98LX is offline
Send a message via AIM to JasonAccord98LX
My car hit some sort of governor/rev limiter at an indicated 138 MPH. It like made this quick buzzing sound, which bumped it back down to like 135, then it hit 138 again and did the same thing. I think the engine was turning like 5200 RPM in 5th gear. I reached this on a slight downhill, the car wont do anymore than 134 or so in a straight line. Im sure this isnt the actual speed, but thats what the speedo says. Drift would probably know more about this, but im pretty sure that its a rev limiter, or possible a fuel cutoff which happens at a certain RPM in top gear.
-Original PH Member-
Registered in May of 2001
'98 Honda Accord Sedan 2.3L VTEC 4cyl 5-speed
Generic Cold Air Intake
205/60/15 Bridgestone Potenza RE950's
Save the Oompa-Loompas.....a site I helped create
http://www.oompa-loompas.net
Old 01-06-2002, 02:33 AM
5speedaccord 5speedaccord is offline
Send a message via AIM to 5speedaccord
Question 110
I was trying to see ho fast i could go tonight and i hit about 105 but it seems to accel very slowly up to 105. is that cause of the gov or will it stil accellerate at that rate with out the gov???
Old 01-06-2002, 03:30 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
all Hondas are governed at 200km/h, about 120mph. the only exception i know of would be the Prelude and ITR... they arent governed. my prelude has no governor... i've redlined 5th gear.
i heard some American built Hondas are also without governor... but my Accord is US built, but is also governed.
they incorporate a fuel cutoff. once you reach the governed speed, fuel is cut by the ECU. you can have this programming removed by any of many chip reprogrammers. the best known and arguably the cheapest would probably be Jet.
if you were to have an ungoverned vehicle, the top speed would be regulated only by gearing and motor output. maybe your gearing would be too low for your motor's output, and reach top gear redline even tho your car is still pulling (the case with my Prelude).
if your motor doesnt have enough output, and gearing is not a limiting factor, you'll hit a point where the motor cannot overcome the force of air as you travel, thus drag becoming the limiting factor.
Old 01-06-2002, 03:31 AM
drift's Avatar
Re: 110
governors dont gradually slow your acceleration... that's drag slowing you down.
Old 01-06-2002, 07:11 PM
1989 DX R's Avatar
1989 DX R 1989 DX R is offline
Send a message via AIM to 1989 DX R
The 01 Accords have the governor set at 95 mph. sucks doesnt it?
Old 01-07-2002, 07:57 PM
toilet_ninja toilet_ninja is offline
They have governer bypass things that run about a hundred bucks. I'm not sure where you can get it though.
Old 01-08-2002, 08:59 PM
I would need to see some proof before I believe that. No offense.
Old 01-08-2002, 11:24 PM
1989 DX R's Avatar
Well, i cannot offer proof like a picture, but my dad's 01 has the governor set at 95.
He was driving west Texas, and wanted to save some time and test the car, it was only 12000 miles old. He has never experienced a governor, but he described it as "I hit 95 and then i couldnt go faster. I had plenty of rpms left, and pushed the pedal all the way, but it stuck at 95."
Thats all the proof i can offer. Its a 2001 LX Sedan, so maybe trim levels have something to do with it?
Old 01-08-2002, 11:36 PM
thats really weird. i have a 98 lx and it doesnt cut out until an INDICATED 138. maybe the 2001's have their ecu's programmed differently. also, this could be way off, but was it a rental car before he got it? cause often times rental companies limit their cars as to how high they can rev and how fast they go.
Old 01-12-2002, 06:36 PM
Dahmin8's Avatar
Dahmin8 Dahmin8 is offline
ECU re programming seem to be the likely answer. 110 mph is the fastest I've gone in my Accord and when I tried to go faster it seem to accelerate really slow. So I just discontinued trying to pull a higher speed. Does anyone know the top speed of a 90 Accord LX and when the gov kits in?
Dahmin8 90 Accord LX
Old 01-12-2002, 11:24 PM
1989 DX R's Avatar
He bought it brand spankin new with only 18 miles on the clock. Probably is the ecu programming.
Old 01-13-2002, 10:14 PM
ShockJon ShockJon is offline
Just topped my wife's 93 accord today!! 115mph..... But it seemed to be pulling the gear pretty good!!! I think I could hit 125+ Without the gov!!! Yes you can call me crazy!!! The car is slow off the line but after that it's a train!!! LOL
1What does it mean when a 1993 Honda Accord needs an service tune up? tools951 Accord/TSX/Accord Hybrid 1 02-12-2011 01:06 PM
1994 Accord EX caster problem xxGriffonxx Accord/TSX/Accord Hybrid 4 11-09-2010 12:18 PM
'94 Accord Appearence Brad09 General Discussion 0 09-08-2009 09:06 PM
2000 Accord Rear Window Malfunction pumatiger Accord/TSX/Accord Hybrid 1 08-03-2009 11:56 PM
90 accord dx 5 spd 2genjohn Accord/TSX/Accord Hybrid 1 04-04-2009 06:50 AM
