Old 02-18-2004, 01:04 PM
goober1 goober1 is offline
1999 speakers
All of the speakers sometimes go out-sometimes comes on.
The radio and stuff appears to work but there is no sound. Sometimes slamming the passenger side door hard will make them come back on. Sometimes hitting a bump in the road will make it come back on, sometimes a bump will make them go out.(If the radio has been turned up alot and the sound suddently comes back on it will dang near cause me to wreck.)
The connection to the back of the radio looks and feels OK. This Tahoe has been ditched but only minor scrapes and scratches to the pass. side.
If the door speaker connection is loose will that affect all the speakers or just that door speaker?
Any other ideas?
Old 02-20-2004, 05:25 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
Re: 1999 speakers
A bad speaker connection will not make the radio inop.
My question is
1)Does the radio lose display, removing all presets, and time.
2)When this vehicle was ditched was there any sort of collision?
Old 02-20-2004, 07:35 AM
Re: 1999 speakers
No- the radio display and everything looks like nothing is wrong. It will scan stations, etc. , the CD player displays all look like everything is ok. It just has no sound-no static no nothing. Presets and time is not affected-????????
The Tahoe ran off the road and sideswiped a fencepost-so I was told. I just bought it and it was already repaired. The is absolutely no visible damage looking from underneath on a rack. The running board was replaced but it did not even bend the brackets that it mounts to. It appears to have been a light sideswipe. No body panels were replaced and there is very little filler material. All the doors shut and align up really well.
Thanks for the replys.
Greg
Old 02-20-2004, 08:04 AM
Re: 1999 speakers
The only reason I asked about the collision is that in the past my friend hit a ditch almost head on in her Jeep cherokee and sliced every important wire in the dash....what a pain in the ass it is to rewire those..luckily I split the work up with another buddy.. I did the Radio he did heater controls and cluster ...never used so many connectors in my life...blah blah blah...
Sounds to me like your volume switch (R56) in the radio is inop or intermittent ... try to wiggle it .. smack it... whatever..
If this is the problem get your solder iron warmed up you'll need it, if not reply back and we'll go from there
Old 02-23-2004, 06:40 AM
Re: 1999 speakers
No luck on beating on the volumn switch. Even took the radio out and shook it around. The only "fix" is slamming the pass. door.
Any other ideas?
Thanks, Greg
Old 07-23-2004, 10:16 AM
jadeashley84 jadeashley84 is offline
same radio problem
hi, im having the exact same problem with my 2001 tahoe, the channels will change the CD player with acept and eject CDs all my settings will save just no sound comes out of the speakers. have you figured out what the problem is with yours yet?
Old 07-23-2004, 11:08 AM
I finally sprayed in and around the volumn knob shaft with a bunch of WD40. I know electronic guys will say NO! NO! NO! but I figured I had nothing to loose and was planning on replacing it with an aftermarket.. It has worked for a few months now without a problem.
Old 08-11-2004, 02:43 PM
Willie0508 Willie0508 is offline
Re: 1999 speakers
on the passanger Side of the dash ther is another fuse panel thing take it of and check those plugs
