Old 02-18-2004, 11:47 AM
aefitch71 aefitch71 is offline
Whats the difference? Please help!!!!
What is the difference between v-tec and non v-tec engines??? i know this sounds like a stupid question but i was just wondering. thanks
Old 02-18-2004, 12:01 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Whats the difference? Please help!!!!
One is vtec, and the other isn't.
What do you want to know, the difference in how the work, look, smell, respond to mods, what?
www.howstuffworks.com type in vtec, if that isn't enough, try www.google.com type in vtec.
Old 02-19-2004, 07:49 AM
juju4uofa juju4uofa is offline
Vtec stand for variable valve timing and lift electronic control. What this means is that when your engine (depending on model) reaches a certain rpm a second set of lobes is engaged on your cam shaft(s). When your engine reaches high rpm your valves or opening and closing many times per second. Idealy the intake valve opens at the top of the intake stroke, but vtec allows the vavle to open a split secong before the top of the stroke to ensure that all of the air/fuel mixture enters the cylinder.
Old 02-19-2004, 08:52 AM
Vtec also requires a couple of other things
Oil pressure 40PSI (make sure there is oil in your motor)
Moving forward @ 20mph+ (so no, you can't hit vtec in reverse or sitting at a redlight)
engine temp of 160 degrees
And be at or past whatever predetermined engine speed your ECU is set for.
Old 02-20-2004, 12:35 PM
pheurton-skeurto pheurton-skeurto is offline
is there any way can rig up my vtec so that i can have it in reverse? i really, REALLY want vtec in reverse...you know like if i get in a fight with my g/f and i gotta make a dramatic effect when storming out of her driveway.
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 02-20-2004, 01:05 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
HAHAHHAHA! i don't know i'm asuming there must be some way maybe in ECU tuning ummm. to be honest i know it sounds dumb but i'd kinda like to know if there a way to rig that up. *not for use but just to know if its doalbe*
