Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-18-2004, 11:17 AM
mitch311 mitch311 is offline
Help on changing rear differential oil.
Hi guys,
It's time for me change my rear differential oil and I need some help. I see the filler plug but can't see the drain plug. Any advice you guys have for me to drain the oil gear oil? Will I have to remove the entire differential cover?
Thanks in advance.
Old 02-18-2004, 12:12 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Help on changing rear differential oil.
Sorry there is no fill plug.
Step by Step:
1. Loosen the fill bolt (so it is easier to remove while the diffy cover is off) with a socket extension on your socket driver.
2. Loosen/ remove the track bar left hand side (I remove the nut from the leftside).
3. Place the pan below the diffy, lossen all the bolts, and smack it a couple of times with a rubber mallet. Let the oil start to drain a bit. (If you remove all the bolts at once you could end up taking an oil bath once your smack it with the rubber hammer).
4. Continue to loosen the bolts and drain the oil.
5. Once you have most of the oil out remove the cover. Clean the mateing surfaces with a putty knife (if this is your first time since the truck was new you will find they used gasket maker stuff).
6. Replace the gasket with a paper gasket (if you want to use the make a gasket stuff that is fine but it will be a mess the next time it comes to change) Fel-Pro # RDS 6629 (7 bucks for the paper gasket at most autoparts stores). The benifit of the paper gasket is the next time you change it it will just pop right off and no or little putty knife work is need. If you dab a little axle grease on the diffy housing it will help to keep the gasket inplace.
5. Replace the cover, tighten it down (use a crossing patteren while tighting).
6. Fill with diffy fluid (note if you need oil with limited slip additive), a cheap 5buck hand pump will help to keep you clean (the hand pump screws onto the top of the oil bottle) and you can use it again and again over the years.
7. Tighten up the track bar and replace the fill bolt and your ready to roll!
Good luck!
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-18-2004, 12:22 PM
Thanks "Amigo-2K",
The part number for the Fel-Pro # RDS 6629 gasket, is it made particular for the 2001 rodeo? Is there any leakage problem using the Fel-Pro gasket instead of the silicone glue type gasket maker?
Thanks again.
Old 02-18-2004, 01:01 PM
Isuzu Guy
Yup the felpro # is for all 98-04 Rodeo's and Amigo's. You have a Dana 44 rear axle in your truck. I personally think there is less of a chance for leakage with a paper gasket then a silicone one since there is no guess work to wonder if you have enuff silicone coverage, and it is easy to pop off the paper one next time.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-05-2006, 11:47 AM
directory's Avatar
directory directory is offline
i know this is an old thread but, i may be doing this soon as i am buying a new diff cover..i don't think the factory tin foil one will work for me...
i have a 4x4...anyone know how to change the front diff cover? and if there are any aftermarket covers for the front? 99 passport 4x4 auto...any tips/tricks?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 01-05-2006, 11:57 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
There is no cover on the front diff, it is solid with the axle. Only the input side of it is removable.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 01-05-2006, 12:03 PM
directory's Avatar
ahhh, that would make sense. ok. thanks!
SKYWARN
we be clubbin'
--B
Old 01-08-2006, 08:43 PM
lifelongslacker lifelongslacker is offline
Word of Advice: unless you can defy gravity, buy a good fluid transfer pump with a long hose. (trust me)
Old 01-08-2006, 09:37 PM
directory's Avatar
yes...i think i might buy 2--one to get the bad stuff out, one to put the good stuff in
SKYWARN
we be clubbin'
--B
Old 01-09-2006, 03:16 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Re: Help on changing rear differential oil.
That's what I did. I threw the pumps out when I was done too. It was kind of a pain to fill the diffs back up.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 01-10-2006, 11:38 AM
mapua82 mapua82 is offline
At 70,000 mi, i haven't change my differential fluid (front & back).
In the front - because i used 4WD sparingly even on winter.
Also i haven't change the transfer case oil too.
In the back - Its because its a limited slip differential and there are no pre-mixed fluids (you have to mix them).
'99 Rodeo SLE 3.2L V6
'01 Camry CE 2.2L
Old 01-10-2006, 12:28 PM
directory's Avatar
there aren't any??? that doesn't sound right.
SKYWARN
we be clubbin'
--B
Old 01-10-2006, 10:26 PM
Gizmo42's Avatar
There's several premixed LSD gear oils. Here is what I used in mine..
http://www.valvoline.com/pages/produ...asp?product=58
Originally Posted by Valvoline
Contains special additives to reduce chattering in limited-slip differentials
Recommended for (conventional and limited slip) manual transmissions where an API GL-5 or MT-1 fluid is specified
--Dave
Rear No-Slip Locker
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
