Old 02-18-2004, 08:14 AM
Deadflyer Deadflyer is offline
Lightbulb 88 F150 Tdc?
Made a mistake!!!!
Had to replace distributor and had electric problem
Finally found broken wire under air filter
Now can't seem to find TDC... I troed pulling #1 and getting piston at top ....even reversed it 180 degrees... but no luck starting truck
Any tricks to ensuring that I have TDC when i insert distributor?
Thanks
Old 02-18-2004, 01:09 PM
THUNDERIN'bird THUNDERIN'bird is offline
Ya, unplug your coil wire, pull the plug on the #1 cyl. and if you don't have a buddy to bump your starter, reach over and jump the solenoid with a screw driver, and wait 'till the compression blows your thumb off of the plug hole. That'll get you close enough to TDC to set your distributor. Or stick a long screwdriver (or anything) in the hole and turn the motor over with a breaker bar on the crank pulley and feel for the piston stopping up top.
BUTTERS: Well, uh, gee wiz, I'm not w-watching television, Dad, I'm just laying here jackinit.
BUTTERS' DAD: Jacking it? Jacking what?
BUTTERS: Well, my hot, spicy, b0ner, of course, Dad.
97 F150 4.2 Roaring PLEASE HELP stanley24538 F Series 7 10-25-2010 07:46 PM
f150 4.6 overheating JoeB64 F Series 3 02-06-2010 09:29 PM
1990 Ford F150 - Flooding? mizshadow420 F Series 1 02-04-2010 08:03 PM
f150 aod shifting problem barshowfamily F Series 2 11-30-2009 08:57 PM
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
