Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-18-2004, 07:03 AM
Drifter To Be Drifter To Be is offline
Forged Pistons & Rods
how much would it cost if i were to replace stock pistons and rods?
i heard from some people its even a difficult and time consuming task for trained mechanics... and i myself is no mechanic so i'll have to find somebody to do it for me.
anybody got their pistons/rods replaced?
how much costed you for parts?
how much costed you for labour?
thanks all
Old 02-18-2004, 09:59 AM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
Re: Forged Pistons & Rods
it depends on what you want to replace them with.
"here are some prices and recomendations for you to talk to your local speed shop or online seller of choice about, this is not an attempt to sell you parts"
eagle rods should cost you $299 + s&H
i prefer wiseco pistons they should be $399-$499 w/rings
cometic headgasket $85-$125
clevite bearring set $75-$100 rods and main
arp head stud kit $150
the cost will depend on if you want a full engine build ie replacing bearrings, oil and water pumps, all seals gaskets. etc.... mileage will make that diff.
a shop should charge around $3500 to do all of the above including labor, machine shop charges, parts, and removal and reinstall
the compression will be determined by how you are using the engine and you should not even order your pistons and bearings until the engine has been disasymbled and checked by the machine shop to see if you need an overbore piston.
note: if you plan on using aftermarket non oem bearings you will HAVE to have the crank turned. every once in a while you will run across a factory honda crank that will allow a "standard bearing set" most of the time you cannot. you see honda cranks, rods, and blocks all have codes stamped onto them that determine the journal size, on a chevy 350 the tollerances are not as close and all of the journals are about the same, on hondas they come with different sized journals. this makes for a tighter and longer lasting engine but if you do not know about it you will have problems.
Old 02-18-2004, 02:09 PM
93hybridaccord 93hybridaccord is offline
My pistons and rods were 1,400.00 alone. They are for pushing serious amounts of boost though. CP pistons, wiseco rings and crower pro-billet rods. I'm sending my block down to Golden Eagle to get sleeved and assembled. Grand total on that is 3k. That includes sleeving, balance and blueprinting, honing, line bore, crank sizing and bearings. I've already got the block tore down by the way, I don't know how much it would cost for them to do that. My grand total on the block is around 4,500.
One thing, it's always a good idea to check out the head while you have the whole thing apart. Depending on the age of the block and how bad it's been hammered on, you may want to change out your springs, guides and seals. Also check to see if any valves are warped or damaged.
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 02-18-2004, 06:53 PM
hey thanks
that helped alot...
but im still not very knowledgeable to modding turbo engine...
wat is a bearing set and wat is a head stud kit??
Old 02-18-2004, 07:05 PM
Originally Posted by Drifter To Be
hey thanks
that helped alot...
The bearings I was referring to are the main bearings on the crank and connecting rods. As far as a stud kit, those would be for the head obviously. Instead of having bolts that you tighten down the head with, you have a stud that is put into the block, then the head goes on and a nut goes on the threaded end of the stud. They are basically stronger than a normal head bolt.
Old 02-19-2004, 06:01 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
In reference to the comment that changing rods and pistons are hard....that person is a moron! sure it may be a bit time consuming, but a dedicated enough person can even do it in their drivewat with just a bit of a lift...there are a few specialty tools required, but even i can do it! and im 15!
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-19-2004, 10:29 PM
I would love to see you rip apart your block and replace your pistons and rods in your driveway. When's the last time you rebuilt an engine, I mean a car engine too.
Old 02-19-2004, 10:34 PM
u can do it?
haha i highly doubt it...
do u even have any hands on experience in modding cars?
have u even done any basic maintenance before? like can u change an oil filter??
wait... do u even have a car?
haha
Old 02-20-2004, 05:50 PM
PunkAlex's Avatar
all righty then....time to redeem myself:
HAh hah driveway may be a little extreme, but its possible...Ive replaced a rod in a tercel in my friends garage (not shop, garage). Took off the hood, went through all of the crap to remove the cylinder head (wiring, removing the intake and exaust manifold, timing belt), lifted the car up bout 2 feet off the ground wiht jackstands, drained the oil, take off oil pan, remove connecting rod nuts, pushed the piston/rod out the top of the block, replaced rod/pin, put ring compressors on the piston and knocked back into block, put #1 piston at TDC, put oilpan back on, blah blah blah...dont tell me ive never wrenched a car before becuase you, my friend, are sadly mistaken!
And yes i can do tune ups and oil changes and shit. I DID have a car, but i sold it cause of excessive frame damage. Please dont patronize me, im not some dumbass punk who goes around and lies all the time. I know what im talking about!
Old 02-25-2004, 11:11 AM
TEAM KLR's Avatar
listen guys! there is a big difference in putting pistons and rods in a car. and "PROPERLY INSTALLING THEM" just like this: it is really easy to make horse power! big shot of nitrous or alot of boost! but it is hard and expensive to make alot of horse power safely and make it last! that is why you don't cut corners on things like engine work and tuning.
Old 02-25-2004, 08:45 PM
PunkAlex's Avatar
Allrighty then, i see another person stuck in the "this kids 15 so of course he's gonna do it wrong and half-assed". Bullshit is all i have to say. What do you want me to go into? bearing specs? torque specs? i check it all dude, and my pals tercel has been put on a lil more than 6k miles since i changed the rod. I dont believe that it would have lasted that long had i not done it right, pal.
Old 02-25-2004, 09:55 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Give him a break. if you read some of his past posts, he is actually pretty knowledgeable. Alot more so than most 15 year olds.
Old 02-25-2004, 10:25 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
I agree.
It is NOT hard to do this stuff. Not rocket science. I've rebuilt a couple of engines, I rebuilt my first engine in my garage with no experience. It is still running and pushing some respectable power. All the specialty tools you need is a ring compressor(cheap) a torque wrench(not so cheap.. around $100 for a decent one), and feeler guages(cheap). If you want to install your own valves, you need a spring compressor. If you have file fit rings, you need a ring filer. My machine shop charges $200 to assemble the short block of a v8, too much for me so I just did it myself. The only thing that really takes any special talent would possibly be blueprinting and setting clearances. Ring filing just requires careful attention. All my machine shop did for me was clean and machine the block and heads. Everything else is essentially bolting together. Don't be scared, it is not as hard as you think.
Are pistons & rods interchangeable when rebuilding '95 3.8 engine? J Parks Bonneville 0 04-29-2010 09:32 PM
forged pistons and rods for KA24E? billclinton 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 10-15-2004 07:18 PM
For Sale: KA24E Pistons & Rods (CHEAP!) Zushi 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 04-20-2004 04:42 PM
Forged Pistons and Rods x86 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 07-30-2002 01:46 PM
