Old 02-17-2004, 11:32 PM
synonim synonim is offline
new coils and no spark
Hey, i have a 95 cav with a 2.2 and it just got both of its ignition coils replaced and now there is no spark. it would start before this happened but it would have trouble and then i found out a coil was bad so i replaced both for safety, (both were the orginals) now i got no spark at the spark plugs. Any help or ideas would be appricated, Thanks.
Old 02-18-2004, 12:12 AM
JERKY420 JERKY420 is offline
Re: new coils and no spark
replace plug wires or recheck you connection into the ignition module
Old 02-18-2004, 02:50 PM
yeah, thats been checked out and found to bee good but im still not getting a spark, any other ideas
Old 02-22-2004, 12:08 AM
thecommi thecommi is offline
Send a message via AIM to thecommi
replace the Ignition module and the crank shaft sensor located behind the module. i'm possitive this will solve your problem
Old 02-22-2004, 09:57 AM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Just don't break the Crank shaft Sensor!!
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 02-23-2004, 08:58 PM
amac209 amac209 is offline
Send a message via MSN to amac209
check the fuses before you waste a bunch of money on parts you don't need. if it worked before you changed the coil packs it's not working because of something you did while changing them. a wire might've backed out of the connector. try hooking up the old coils and see what happens. it's highly unlikely you have 2 new coils that are bad but i've seen some strange things happen.
