Old 02-17-2004, 10:59 PM
Anaudiophile Anaudiophile is offline
88 Civic EFI Idle flare
Hi Guys! Can someone shed some light on this problem? When cold starting my Civic the idle constantly flares up and down by a few hundred rpm. It goes away once the engine is at normal operating temperatures?? Drives me nuts when it happens though. UPDOWNUPDOWNUPDOWNUPDOWN...............
THANKS
Old 02-17-2004, 11:16 PM
habib_88's Avatar
habib_88 habib_88 is offline
Re: 88 Civic EFI Idle flare
Hmm, if its a 1.5 that sounds like the TPS sensor or there is another sensor that goes bad on the 1.5 i just forget what it is. But yea my old DX did that alot, check your ECU it might be throwing a code without turning on your engine light mine would do that also. And if all else fails maybe this can help?
http://www.g2ic.com/forums/showthrea...threadid=42969
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 02-17-2004, 11:17 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
mine does it when its hot, just a high idle when its cold, no idea what it is. i'm gonna go ahead and replace all the sensors around the throttle body and also the map, we'll see if that helps
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 02-18-2004, 06:08 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
I used to have that problem.
First check to see if all your hoses on your intake manifold are connected. If one of these comes loose, it'll cause ur idle to lope.
If its a code 3 and/or 5, its your MAP sensor (the one mounted on the firewall). If it's a code 14, that's your EACV (cylinder on the back of the intake manifold). Last but not least, it could be your TPS (not likely) which is located on the throttle body.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
