Old 02-17-2004, 10:12 PM
ice_rr's Avatar
ice_rr ice_rr is offline
Send a message via ICQ to ice_rr Send a message via AIM to ice_rr Send a message via MSN to ice_rr Send a message via Yahoo to ice_rr
how many hp would i pull out of vtec h22 with a 7psi tubro?
hi all i know that the h22 is like 190hp how many hp would the turbo give it?
thanx!
Old 02-17-2004, 10:26 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: how many hp would i pull out of vtec h22 with a 7psi tubro?
i read that per 1psi = 10 hp, so...260hp?
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 02-18-2004, 08:18 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Well that depends on the turbo setup you have. The general rule is like he said, 1psi=10hp. That is give or take though. Naturally a larger turbo will produce more power and a smaller one less. What size turbo are you thinking of?
What H22 are you talking about? (year and usdm or jdm) The JDM have a little more power because the USDM c/r is 10:1 while the JDM is 10.6:1. Also the JDM type S has 11:1 c/r. You really don't need to boost to much on the high compression. 7psi should be ok. Getting the power to the ground is going to be your worst problem.
Also other factors come into play.
Are you using an intercooler, FMIC, SMIC?
Is it tuned to it's best?
Any aftermarket parts?
Also if I can ask what car are you putting this in? It's going to be hard if you are putting it in a 4g.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-18-2004, 11:04 AM
ice_rr's Avatar
ok here how it goes! im plaining on getting an 95gs integra... after i got it im going to get the best vtec... wich is a h22 vtec... after plaining to spend 2k on a good turbo... what would be the strongest enin other than h22?
thanx
Old 02-18-2004, 04:49 PM
Re: Re: how many hp would i pull out of vtec h22 with a 7psi tubro?
thanx
2k on a good tubo? I'll sell you a perfect one for 3k You can piece together your own kit and spend about $1000 and have the exact parts you want. If it was me I would keep the B18 in the teg. Take the money you plan to use to buy the H22 and put it in teg parts. ie: Forged pistons, rods, cam shafts, port and polish the head, oversized valves, clutch, etc, etc. For what you will pay for the H22 swap you can have a built B18 with a t3/t4 turbo (for example) pushing 10 psi that will leave the H22 in the dust. Not only that with the built engine you can jack the boost up.
Old 02-18-2004, 05:33 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
horsepower with a turbo on is calculated like this:
you start with your A/F ratio. lets say for example your A/F ratio is 12:1. (most likely its between 14 and 15 on your stock civic if its running good.) So, if you run 12 pounds of boost (psi), youll double your HP. For example if you've got an A/F ratio of 13.5:1. Let's also say that your car has a peak HP ratio of 110 HP. So, if you run 13.5 psi, you'll have approximately 220 HP. Get it? This is a better explanation that 1 ps i= 10 HP.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-18-2004, 09:51 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
well it takes 1 Bar (14.7 PSI) to double your HP So using that 7/14.7=0.47619 190 * 1.47619 = ~280 HP at seven PSI.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 02-18-2004, 10:05 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
If you do turbo the H22 (if you get it) make sure you build the bottom end up as good as u can, bc i heard they have weak bottom ends, compared to all other honda engines i mean.
1991 Honda Civic DX Sedan
Old 02-19-2004, 03:29 AM
kapt kapt is offline
Send a message via AIM to kapt
turbos are overrated. i would go all motor, then add a turbo later if u still want. start from the ground up so u dont cut any corners.
get a b18c1 or c5 and put it in ur integra, then move from there. the h22 is gonna fuck ur handling and its not worth the extra dough.
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
Old 02-19-2004, 02:45 PM
Hybrid1990crx's Avatar
Extra dough? A h22 will run you cheaper than a c1 or c5. Installation will be more of a bitch and maybe it will cost more in the long run.
Old 02-19-2004, 07:55 PM
Turbo's are over rated? Yeah right, turbo is the best way to increase your HP for the $. $1000 worth of turbo parts can get you aroung 300 extra hp. Can an all motor setup do this for $1000? No... A built turbo motor will run a lot stronger than an all motor.
Old 02-20-2004, 07:41 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
I say go with a super charger instead of a turbo
KoRnSaQ
Old 02-20-2004, 09:40 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
why?
and what supercharger would you use?
As American As A Burrito!
USDM 4 life!
