Old 02-17-2004, 07:52 PM
elysian elysian is offline
'97 Escort EGR Problems, Error Codes P0401, P0402
My MIL check engine light came on and has stayed on for quite a while now. I finally decided to look into it.
I've been getting both error codes P0401 (insufficient flow detected) and P0402 (excessive flow detected). I initially thought it was a bad EVR solenoid and changed it out with a brand new one from the dealer and reset the codes. Less than 24 hours later, the two error codes came back on. Then I thought it could be a stuck EGR valve so I got a new one and swapped it with the old one. Same thing happened, the two codes came back on in less than 24 hours.
Has anyone else had the same problem? What else could it be?
Thanks for your help.
Old 04-20-2004, 09:08 PM
CAAMARO CAAMARO is offline
Re: '97 Escort EGR Problems, Error Codes P0401, P0402
I have the same problem, but my mechanic "cancelled" the egr valve and solenoid, and told that this valve doesn't affect the performance of my vehicle. Is this True..??
Old 04-20-2004, 09:36 PM
The problem, it seems, had to do with the DPFE (Differential Pressure Feedback EGR) Sensor. Apparently, Ford is notorious for making defective DPFE sensors. I read on some other forum that if Fords give those error codes, it's most likely the DPFE sensor and so I gave it a shot. I went to Autozone and bought one (it's called EGR Valve Pressure Sensor) for around $55 and installed it in around 15 minutes. The error codes never came back.
So, if you're still having this problem, you might want to give the DPFE sensor a shot.
Hope this helps!
Old 04-21-2004, 10:26 AM
I'll give it a try...Thank you very much.
Old 04-23-2004, 02:30 PM
Hi, Again....are The Egr Valve Possition Sensor And The Egr Valve Pressure Sensor The Same....?????
Thanks
Old 04-23-2004, 02:36 PM
I'm not sure what an EGR Valve position sensor is, sorry.
You should check at http://www.autozone.com for the EGR Valve Pressure Sensor.
Old 04-27-2004, 03:26 PM
jerry1121 jerry1121 is offline
Hi
What are tools I need to replace the DPFE sensors? I have a 99 ford taurus with the same problem.
Old 04-27-2004, 03:42 PM
I think all I used was a socket wrench. I don't remember which size though. Nothing special.
Old 04-27-2004, 03:54 PM
for the escort was a 5/16". Maybe you'll need two of them.
Old 04-28-2004, 07:46 AM
Thank you so much. The mechanic charges $80 for labor.
Old 04-29-2004, 08:29 AM
I have put on a new EGR valve pressure sensor. But the engine light is still on. Then I disconnected the battery for 3 seconds and connected it. The light is off. Is this right? Do I need to do that. I quite worry about this light come back again.
Old 04-29-2004, 04:42 PM
normally you reset the light with the computer. But I heard that some people disconnect the battery in order tu shut the light off. But I'm not sure if it's the same thing....
Old 04-29-2004, 08:42 PM
Jerry, you should put some miles on the car -- probabliy around 50-100 miles or so. If it doesn't come back on, it should be fixed.
Old 05-03-2004, 07:49 AM
Thanks
Actually, I have put 1k miles last weekend. It still does not come back.
Old 05-05-2005, 04:00 AM
mannydingo mannydingo is offline
I have a 1998 Ford Escort SE. I had that code also, bought the DPFE (Differential Pressure Feedback EGR) Sensor at AutoZone that the person before mentioned and the code still came back. $55 down the tube. I guess it was good to get out of the way that it was not the sensor. I am going to have to physically check the whole thing out. I guess I was just trying the expensive lazy man's way out. It's just that I read that the sensor was the problem 95% of the time so it was worth the chance. I, ofcourse, reset the computer.
