Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-17-2004, 06:23 PM
llaque llaque is offline
Exclamation need help!!!!!!
I need help with my b16a, I recently swap to CTR cams, i notice difference, but I think I can take out more from my car, maybe a ECU reset (that helps???). I donīt have cam gears, but I have Apexi VAFC, and fuel pressure reg. , CAI injen, DC header&exhaust, and some other mods.
Can someone can help me???
Old 02-17-2004, 07:51 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: need help!!!!!!
I am not sure what it is that you are asking. And what kind of car do you have?
Old 02-18-2004, 12:45 PM
ok, my question is if i need to reset the ECU, after installing CTR cams, I have a acura integra XSI, with a b16a.
Old 02-18-2004, 05:55 PM
whtteg's Avatar
Re: need help!!!!!!
Ahh I see you don't live in the U.S Ok yes it would be a good idea to reset the ECU, but it would aslo be a good idea to get either a hondata or Vafc to tune the fuel an ignition. Are there any shops with a dyno and a person who know how to tune around where you live?
Old 02-20-2004, 01:19 PM
Re: Re: need help!!!!!!
I already have a apexi VAFC, and I have a Dyno near my house too.
I need to put more fuel into the chamber??????
how much??????
Old 02-20-2004, 03:58 PM
whtteg's Avatar
Re: need help!!!!!!
You have to get it on a dyno with a wideband to find out.
Old 02-28-2004, 04:35 PM
please somebody help me.......
I have a b16a, with CTR cams, CAI, exhaust, DC 4-2-1 header, fuel press reg., apexi VAFC..
Ok , my question is:
I found a nice configuration for my apexi, and I open vtec at 4500 rpm, but... How many degrees adavance/retard the ignition timing, one??? two??? three??? anybody knows????
thanks
Old 02-29-2004, 12:24 AM
integralover's Avatar
integralover integralover is offline
whtteg knows what he's talking about, you might want to listen to him or be a little bit more clear on what you are actually looking for.
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 03-02-2004, 03:45 PM
whtteg's Avatar
Re: need help!!!!!!
thanks
Ok you are not listening to me! You have to get the car on a dyno and hook up a wideband 02 sensor to the car to tell you where in the rpm range you need to add or remove fuel and where to add or remove timming. It is as simple as that, without the wideband there is no way of knowing where to change the settings. You cannot assume that someone else that has a setup close to yours that has had it tuned can give you the correct adjustments, because they will not be what your motor needs. Every motor, even the same exact kinds, are going to require different fuel and ignition maps when tuning.
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
need help removine vent on passenger side of dash in 94 accord? need help on removing 94cordvtec Accord/TSX/Accord Hybrid 2 01-23-2005 09:50 PM
Help Help Help!!!!! Need Help! shahram177 Off-Topic 12 11-09-2004 07:22 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Need Help On What Glue I Need For Body Kit Installation....HELP PLZ!!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-13-2002 08:24 PM
