Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-17-2004, 02:11 PM
ThadAyazides ThadAyazides is offline
97 Jetta loud cat conv/tiny engine stalls
Hey all!
Last year the catalytic converter on a 97 Jetta was replaced because it failed emissions and there is a federal warranty on cat. convs. which says if your car is under 80,000 miles you get a new one for free. So that was done, Now about one year later the cat conv is sounding loud and the car will have tiny stalls here and there. Could the cat conv have went bad again? Is there a different problem? It has trouble especially after stopping at a stop light and beginning to accelerate. THere have been new plug/wires, fuel filter recently put on.
Any help would be awesome!!!!!
Old 02-19-2004, 09:35 AM
boschmann boschmann is offline
Re: 97 Jetta loud cat conv/tiny engine stalls
Does the check engine light come on?
Old 02-19-2004, 01:24 PM
No the engine light didn't come on, and no codes given off either. VW found the problem, an exhaust pipe leak, it sounded around the area of the CAT. Hey, do you know a good computer code reader for a car?
Old 02-20-2004, 09:13 AM
termitesgraffix's Avatar
termitesgraffix termitesgraffix is offline
Send a message via AIM to termitesgraffix
is the cat loud sputtery sound? or is it a rattle of sorts.. could be broken inside and clogging the pipe????
Old 02-21-2004, 08:18 PM
Ross Tech makes a VW Group dedicated VAG simulator for PC that basically does everthing a dealer can.
http://www.ross-tech.com/
I would also make sure you ignition coil is okay, they were very common to fail. Try spraying it with water & see of those little stalls & acceleration trouble gets worse.
Old 02-24-2004, 06:39 PM
jacee74 jacee74 is offline
Where did you here that it was federal law to replace cc with under 80k miles. Please let me know where I can find such information.
Old 02-25-2004, 05:24 PM
It's in the warranty section of all owner's manuals
HELP! 98 Jetta-Fan keeps running after engine is off Sunshine17 '97 - '03 3 01-17-2010 12:47 PM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
96 Jetta Cat. Conv. part # jett-n-along '91 - '96 1 04-13-2006 08:44 PM
CAT CONV glowing red hot/ engine rough idle/rough ride F-BRD_fan Camaro Discussions 4 03-01-2006 04:12 AM
Any Kiwis Removed Cat Conv?? BETTER THAN A WRX Engine 6 06-30-2002 07:28 PM
