Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 02-17-2004, 12:16 PM
woodsonj3 woodsonj3 is offline
possible drivetrain problem?
I have a 95 corolla with 150K miles that is making a hollow clunking noise when accelerating/decelerating. It has to be one of 3 things but so far after taking it to 2 shops and replacing motor mounts no solution found so far.
1) Motor Mounts - Been there, done that. Didn't fix the problem.
2) CV joints - good possibility but the boots are still intact and I'm not getting the clicking noise that everyone talks about. I do however get a shutter going up hills and braking at higher speeds (say >40 mph).
3) Differential - Haven't found much info on how to diagnose this one but I did read somewhere it could be causing the noise. Not even sure how to fix it if differential gears are the problem. Transaxle shifts normally.
Thanks for any insights.
Old 02-17-2004, 12:33 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: possible drivetrain problem?
Have you checked the wheel bearings, ball joints and other front suspension components?
Old 02-17-2004, 01:18 PM
No. I kind of got off on the drivetrain being the problem after doing a little research on it. I just don't know how to isolate it to one thing or the other. I'm taking the car back to shop that did the motor mounts tomorrow. Although it was an honest mistake it did not fix the problem I asked them to fix. I mean may be the motor mounts were "weak" but I would have rather had the noise fixed.
98 tahoe "bump & clunk" drivetrain problem HONDA-CYCLES C/K 19 12-02-2010 03:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
95 corolla drivetrain problem woodsonj3 Corolla/Matrix/Voltz 11 07-29-2004 07:31 AM
drivetrain problem woodsonj3 Engineering/ Technical 1 02-17-2004 09:35 PM
BIG drivetrain problem Jay eS Iye '88 - '91 Civic | CRX | Wagon | Shuttlee 12 09-06-2003 12:32 AM
