Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 02-17-2004, 09:37 AM
prakash22 prakash22 is offline
Send a message via MSN to prakash22
celica gt4 not climbing hill
HI , I have a toyota Celica GT4 1990 Model. I had problem when I climb a hill the enging is missing so I have to rave the engine and thene it climbes but there is some thing wrong. I have just put new spark Plugs but still. then when I drive all ofa sudden when the rpm is high it runs very high without pulling.Please advise
Old 02-17-2004, 11:48 AM
jaggedyer jaggedyer is offline
Re: celica gt4 not climbing hill
Is it actually missing or just revving high without torque? Do you have 5spd or auto? If your running an auto its possible your low on transmission fluid and the torque converter cant work properly. Check that and if it just doesnt give the right amount of pull its possible your running lean do to a bad sensor. If its actually MISSING (shaking heavily) chreck the plug wires, distributor cap, rotor etc.
Old 02-17-2004, 11:50 PM
Team_Omega1's Avatar
Team_Omega1 Team_Omega1 is offline
i had the same problem with my 91 alltrac but it was because i accidentally left my e-brakes up...(duh)...but other then that im not to sure of the problem...oh and by the way gt4's and alltracs never came in automatics
Old 02-18-2004, 12:36 AM
Re: Re: celica gt4 not climbing hill
Thanks Jackob!! it ia 5 speed manual, I ahve put new spark plugs what should I check next, let me check the rotar today and see, the plug wires are ok there is no leak.. some times thew engine check light comes on and when I rave it goes off.. Thanks When the car is not on gear the enging is running very well I can rave without it missing.
Old 02-23-2004, 08:51 AM
Celica Gt4 Engine Check
Hi,
I have changed the clutch plates, plugs, plug cables, but still my car could not climbe a hilly road. then I get the engine check light on after starting it does not go off please help
Old 03-02-2004, 04:26 AM
Sypherz28 Sypherz28 is offline
Send a message via AIM to Sypherz28 Send a message via Yahoo to Sypherz28
Well to me if you are having hill trouble then you should be experiencing trouble on the straight aways too. Unless when you hit a hill something is moving when the car is climbing (ie. liquid). With mine I can't slimb steep hills either because there is water in my gas tank, the engine starts sucking water causeing it to miss and bog down. And the only way to fix that is rev up to higher RPM's. It's actually fairly easy to get water in your tank especially with older cars it can build up over time. You could completely drain your gas tank which is my method or you can purchase this stuff that goes into your gas and latches onto the water molecules causeing it to mix with the gas instead of sitting on the bottom of the tank. Then it's slowly burnt away.
My final answer... Water in your gas
Old 03-02-2004, 04:41 AM
Thanks SYPHER. Ok I found the hose pipe which is from the aircleaner going to the turbo was leaking now I have replaced with a new hose pipe. but still I have a problem. even on the normal road I cannot takeoff like i used to do before. it bogs down. It can gradually take off but not instantly...
Old 03-02-2004, 04:56 AM
If your running turbo, and you run your car hard, and if it has some age to it you may want to give her a good rebuilding. Get your valves checked and get the head dipped. You should see a great performance boost or at least get somewhat closer to her origional state
Old 03-02-2004, 05:00 AM
I have a 1988 Chevrolet Beretta with only 90 HP.. I rebuilt that motor replacing only the necessary seals that need changing when rebuilding.. I had the head dipped, valves checked, and I cleaned the tops of the pistons (that takes extreme care) and I can get the little 90 HP engine to run very nicely.. Just give your car some good TLC and you'll be good to go..
