Old 02-17-2004, 03:48 AM
dk91hb dk91hb is offline
Send a message via AIM to dk91hb
engine swap (need info bad)
i have a 91 civic hatchback with the d15b1 engine and i have a 88 or 89 5 speed crx tranny and i just got an 88 acura integra ls for 75 buck the body is shot i want the engine and computer now the integra has the d16a1 dohc engine in it now the question is can i put the engine in to my car without changing trannys and what else do i have to do?????
Old 02-17-2004, 03:53 AM
lilol89crx lilol89crx is offline
Re: engine swap (need info bad)
d16a1 will bolt up to your tranny....not to sure if the 88 teg clutch splines will match up to the tranny. theres some wiring mods that you will have to do as well as swapping driver side motor mounts. IMO i would use the teg tranny as well as the front knuckles n axles.
Old 02-17-2004, 03:55 AM
here is the problem i have a stick and the ls is auto what do i do????
Old 02-17-2004, 03:58 AM
use the b1 flywheel and clutch....you are going to have to do the mpfi swap also.
Old 02-17-2004, 04:15 AM
GTA's Avatar
GTA GTA is offline
Whee..
as far as i know, the d16a1 out of a first gen integra doesnt bolt into our cars. and that it was take some fabrication to fit it in. like moving where it mounts to the car. good luck.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-17-2004, 04:56 AM
Re: Re: engine swap (need info bad)
i have the flywheel and clutch from an 88 or 89 crx mpfi on my engine now will that help any??? solid mount the car???
Old 02-17-2004, 07:11 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
86-89 Integra engines have the same mounts as the 84-87 Civic, not the 88-91 so it won't bolt in. Making custom mounts is sort of a waste of time because you might as well get a DOHC ZC engine instead since they're more powerful.
Old 02-17-2004, 10:46 AM
ok then what about a d15z engine it is out of a vx civic???
Old 02-17-2004, 03:06 PM
odd... buddy of mine put a a1 into his 4g.....from what he said it wasnt a problem
Old 02-17-2004, 06:44 PM
i need to know what he did excatly so i can do it
Old 02-17-2004, 06:54 PM
travagliante's Avatar
travagliante travagliante is offline
Personnally i wouldnt bother with that engine. Its the american version of the dohc zc. Not too much for power and it would take to much to get it.
CHECK THE FAQ...
http://www.automotiveforums.com/vbul...d.php?t=118785
Old 02-18-2004, 10:39 PM
will the intake manifold work on my engine?? if i get the ecm and ecu plus wiring
Old 02-18-2004, 11:22 PM
ecm=electronic control module
ecu= electronic control unit
SAME THING
The best intake manifold would prolly be the one already on the engine. Otherwise i dont know which engine that you decided on.
Old 02-18-2004, 11:43 PM
i have a d15b1 block with a d15z1 head on it and i want to put a d16a1 intake manifold with wiring and ecu
