Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-17-2004, 01:10 AM
zacremacle's Avatar
zacremacle zacremacle is offline
How to adjust the idle
I have not been able to figure out how to adjust the idle on a 95 240sx auto if anybody knows please reply
Old 02-17-2004, 01:15 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: How to adjust the idle
First, drive your car around for awhile until it's at normal operating temperature.
1. disconnect the tps (This is the throttle position sensor. It's connected to your throttle plate shaft. You'll find the sensor on the side of your throttle body)
2. Start the engine
3. Rev the motor a couple times up to around 4k RPM and then let idle again for a couple minutes.
4. Now adjust the idle by turning the idle screw located under the intake manifold. the screw is visible through the 1st and 2nd runners if your standing in front of the vehicle.
5. Stop the motor
6. Reconnect the tps
7. Start the motor
8. Rev the motor to around 4k a copule times and let idle for a couple minutes.
9. Now check your idle again. If it's at what you want then your good to go. If you still want to raise/lower it then repeat the previous steps.
Old 02-17-2004, 02:34 PM
musicsurfman musicsurfman is offline
Send a message via AIM to musicsurfman Send a message via MSN to musicsurfman
Or You Can Do It The Ghetto Way And Preload The Throttle Cable!
There Are Three Methods Actually:
J Specs Proper Way (best Method)
Preloading The Throttle Cable
Or Adjusting The Timing Screw On The Ecu If Your Is Equipped With One.
Old 02-17-2004, 11:02 PM
zacremacle's Avatar
would you be able to post a pic of the tps Because i dont really know what it looks like and my car has been idiling around 1100 and havent been able to find out how to lower it
Old 02-18-2004, 07:49 AM
Tps Is The Little Black Box On The Throttle Body.
Old 03-17-2004, 01:23 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
where is the idling screw? I can't find it under the intake manifold....
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 03-17-2004, 03:08 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: Re: How to adjust the idle
its there, just what jspec said
its on the intake manifold (passenger side of engine)
438whp / 373tq - 11.9 @ 126
Old 03-17-2004, 03:28 PM
is it possible you can send me a pic of it. I been searching and I can't find a screw....I must be blind or something....I see the tps the black box connected to the throttle body, just can't find that screw....
Hiya...
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 03-17-2004, 05:05 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
It should be in the rear of the intake manifold right on the end of the lower part. Phillips head set screw.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-17-2004, 08:15 PM
I am curious if changing the idling can mess up the engine....cause now my engine won't start and I don't know why. the last thing i did was adjusting the idling.
Hiya...
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Nismo 2-Way LSD
Injen Intake w/ CAI
