Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-17-2004, 12:19 AM
eclipse2quick21 eclipse2quick21 is offline
Compression ratio of KA?
what is the compression ratio of the ka24de? thanks in advance.
Old 02-17-2004, 12:13 PM
VQuick VQuick is offline
Re: Compression ratio of KA?
IIRC, it's 9.4, 9.5, something like that. It's okay for FI, if you do your tuning right. If you're going NA, you'll probably want something a bit higher.
“What does ‘kouki’ mean? Are you saying my car is crazy or something?”
Scott-Revs: Motown Muscle
Old 02-17-2004, 01:58 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
1989 KA24E - 9.1:1
1990 KA24E - 8.6:1
All KA24DE - 9.5:1
Old 02-17-2004, 05:01 PM
Re: Re: Compression ratio of KA?
Originally Posted by J SPEC SilEighty
1989 KA24E - 9.1:1
1990 KA24E - 8.6:1
All KA24DE - 9.5:1
thanks yall.....do you think that would be safe to run turbo + nitrous or should i bring it down a little more to around 8.5 or so?
Old 02-18-2004, 06:15 PM
A ratio of 9.5:1 should be okay for mild FI duty. If you plan on going for broke, some low comp pistons would definitely be a good idea.
For nitrous, you should probably stay stock. If you lower the compression to 8.5:1 for nitrous, your performance will suffer when you aren't spraying.
Old 02-19-2004, 05:32 PM
thanks for the info, but i was asking for turbo and nitrous together what do you think i should lower it to?
Old 02-20-2004, 11:16 AM
It depends on how much you're running. I suppose 8.5 would be okay.
If you're running quite a bit of boost and add nitrous to the mix, you'll have more to worry about than just the comp ratio on your pistons.
Unless you are running a turbo the size of your head like a T-78, and need the nitrous to help spool up, you can really just stick with boost.
Old 02-20-2004, 05:19 PM
thanks that was great info....im not only doing the pistons im rebuilding the whole engine...every internal...thanks again though later
