Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 02-16-2004, 10:12 PM
VWJetta29 VWJetta29 is offline
Oil foam? on oil cap?
My oil cap and suronding area looks like "peanutbutter", what is the cause of this. There is nothing on the dipstick. Should i have this checked out?
Old 02-17-2004, 10:27 AM
termitesgraffix's Avatar
termitesgraffix termitesgraffix is offline
Send a message via AIM to termitesgraffix
Cool Nothing to worry about, you are fine.
You should read posts of others, cause a few posts before your's, I responded to Climnjetta's same question. Read below is what I wrote to them. You have the same thing. Nothing to worry about kid.
If it is on the underside of the oil fill cap, then it is just condensation and nothing to worry about. Pull out the dip stick and see if that looks wrong. If there is "milk" on the dipstick then you have a problem, that meens your head gasket is blown. REPLACE NOW!!! (have you lost power?) also check in the coolant tank. if there is water in your oil, then there is oil in your water/coolant. So the coolant tank will look milky. That is bad. Like I said though, if it is just "peanut butter" under the cap and nowhere else, then it is alllllllll good.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
