View Poll Results: Do you like the New Mustang?
I like it 31 75.61%
I don't Like it 3 7.32%
It's ok 5 12.20%
KEEP THE OLD MUSTANG! 2 4.88%
Voters: 41. You may not vote on this poll
Old 02-16-2004, 06:25 PM
TheScientist's Avatar
TheScientist TheScientist is offline
Banned
THe new 2005 Ford Mustang
Do you like its nostalgic styling? Do you think it's a pure mix of the classic Mustang from the '60s and present day texture?
Specs, Compliments of Car&Driver Mag:
2005 FORD MUSTANG
Vehicle type: front-engine, rear-wheel-drive, 4-passenger, 2-door coupe
Estimated base price: $18,000
Major standard accessories: power windows and locks; remote locking; A/C; cruise control; tilting steering wheel; rear defroster
Base sound system: Ford AM/FM radio/CD player, 4 speakers
BASE ENGINE
Type V-6, iron block and aluminum heads
Bore x stroke 3.95 x 3.32 in, 100.4 x 84.4mm
Displacement 245 cu in, 4009cc
Compression ratio 9.7:1
Fuel-delivery system port injection
Valve gear chain-driven single overhead cams, 2 valves per cylinder, hydraulic lifters
Power (SAE net) 202 bhp @ 5250 rpm
Torque (SAE net) 235 lb-ft @ 3500 rpm
Redline 5750 rpm
OPTIONAL ENGINE
Type V-8, aluminum block and heads
Bore x stroke 3.55 x 3.54 in, 90.2 x 90.0mm
Displacement 281 cu in, 4601cc
Compression ratio 9.8:1
Valve gear chain-driven single overhead cams, 3 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timing
Power (SAE net) 300 bhp @ 6000 rpm
Torque (SAE net) 315 lb-ft @ 4500 rpm
Redline 6000 rpm
DRIVETRAIN
Transmissions 5-speed manual, 5-speed automatic
Final-drive ratio 3.31:1
DIMENSIONS
Wheelbase 107.1 in
Track, front/rear 62.3–62.8/62.5–63.0 in
Length/width/height 187.6/72.1/54.5 in
Ground clearance 5.7–5.8 in
Curb weight 3300–3500 lb
Weight distribution, F/R 53.0/47.0%
Curb weight per horsepower 11.7–16.3 lb
Fuel capacity 16.0 gal
CHASSIS/BODY
Type unit construction
Body material welded steel stampings
INTERIOR
SAE volume, front seat 53 cu ft
rear seat 33 cu ft
luggage 12 cu ft
Front-seat adjustments fore-and-aft, seatback angle, height (optional); driver only: lumbar support
Restraint systems, front manual 3-point belts, driver and passenger front and side airbags
rear manual 3-point belts
SUSPENSION
Front ind, strut located by a control arm, coil springs, anti-roll bar
Rear rigid axle located by 3 trailing links and a Panhard rod, coil springs, anti-roll bar
STEERING
Type rack-and-pinion with hydraulic power assist
Steering ratio 15.8:1
Turns lock-to-lock 2.8–3.1
Turning circle curb-to-curb 34.4–34.7 ft
BRAKES
Type hydraulic with vacuum power assist and anti-lock control
Front 11.5–12.4 x 1.2-in vented disc
Rear 11.8 x 0.7-in vented disc
WHEELS AND TIRES
Wheel size base, 7.0 x 16 in; GT, 8.0 x 17; opt GT, 9.0 x 18 in
Wheel type cast aluminum
Tires base, BFGoodrich Traction T/A, P215/65TR-16; GT, Pirelli, P235/55WR-17; opt GT, BFGoodrich g-Force T/A KDW2, P255/45ZR-18
C/D-ESTIMATED PERFORMANCE
Zero to 60 mph 5.3–7.5 sec
Standing 1/4-mile 14.1–15.5 sec
Top speed (governor limited) 118–150 mph
ESTIMATED FUEL ECONOMY
EPA city driving 18–20 mpg
EPA highway driving 24–29 mpg
Old 02-16-2004, 07:52 PM
Tony H Tony H is offline
There are certain details I wish they had done in a different way, but she is the most beautiful car to wear the name since the 60s in my opinion.
Old 02-16-2004, 08:13 PM
justacruiser's Avatar
justacruiser justacruiser is offline
Banned
Re: THe new 2005 Ford Mustang
Ditto, the rest of them were chunky and un-stylish by comparison.
Old 02-16-2004, 08:15 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
I really didn't like the original desigen back in 2003. But the final product is just a work of art. Put me on the list to buy one!
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-16-2004, 11:54 PM
SIKCRX SIKCRX is offline
i only like it in black.
Old 02-17-2004, 01:06 AM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
I guess I would have to keep it if someone gave me it.
Old 02-17-2004, 01:13 AM
nvrenough nvrenough is offline
It's ugly. No more. No less.
Old 02-17-2004, 04:50 AM
Zwrangler's Avatar
Zwrangler Zwrangler is offline
the new mustang is an absolute stunner. and this is coming from a camaro guy I loves the new stang and I hope to own one of those beauties one day. I mean whats not to love? muscly old school classic looks combined with new, a beefier 300hp engine (long overdue) and just plain sexy muscle. I love it
93 camaro Z28 R.I.P.
From this......................to this and this
check it out at my website
"Pain heals, chicks dig scars but glory is forever !"
Old 02-17-2004, 04:52 AM
Zwrangler's Avatar
its quite affordable too for all the options you get.
Old 02-17-2004, 07:12 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
yay! a convert! =P
i love that car, i wish i could drive one. too bad i'm a poor college student who can barely afford to feed himself. oh well, at least my notch runs now.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-17-2004, 10:59 AM
DeViL DeViL is offline
Personally I wish the front was a little more aggressive looking.
'01 S-10 Xtreme - Supercharged 4.3L V6, 10 psi.
'88 Firebird Trans Am GTA - 5.7L V8, 4spd auto.
'06 GTO Brazen Orange Metallic - 6.0L V8, 6spd (the new toy/daily driver)
Old 02-17-2004, 11:08 AM
noswell's Avatar
noswell noswell is offline
Send a message via ICQ to noswell Send a message via AIM to noswell Send a message via MSN to noswell Send a message via Yahoo to noswell
Unhappy Re: Re: THe new 2005 Ford Mustang
iam new here!!! answer me
Old 02-17-2004, 11:21 AM
noswell's Avatar
guys r u there
Old 02-17-2004, 03:56 PM
Teak Teak is offline
Send a message via ICQ to Teak Send a message via AIM to Teak
Amen. The front-end does not look sporty at all. The design is definitely growing on me though.
Old 02-17-2004, 06:08 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
I hate the looks and retro design, as you can tell from the picture below, but the engine is deffinatly a step in the right direction with variable intake and exhaust timing... i can't wait to take that baby for a test drive when it comes out just to see what vtec is like from a torquey v8 opossed to week weed wackers
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
2011 Ford Mustang Specs Leaked (400hp!) iafb83 Automotive News Desk 1 09-11-2009 02:31 PM
2005 Nissan 350Z VS. 2005 Ford Mustang GT nissan350ztt Car Buying Q&A 58 03-27-2006 08:53 PM
2005 Ford Mustang GT vs. 2004 Ford Mustang Mach 1 3000ways Car Comparisons 6 11-17-2004 02:59 AM
2005 Ford Mustang Boss MysteriousGT1 Mustang Talk 21 10-06-2003 12:43 PM
