Old 02-16-2004, 11:02 AM
RichSpyder-T RichSpyder-T is offline
Angry Problems shifting...y?????
while im driving it feels like i have to force my way into every gear. the shifter doesnt just sldie into gear like it used to and when i get ready to go in reverse, i have to force it in and then i hear this weird sound as im getting it into reverse. what the hell is this problem, its really frustrating!
Old 02-16-2004, 01:31 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: Problems shifting...y?????
Shift lock.
Have your tranny checked.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 02-16-2004, 09:35 PM
1gEclipseTurbo 1gEclipseTurbo is offline
Send a message via AIM to 1gEclipseTurbo
hi , i had the same problem in my car , i put in a new master cylinder and adjusted and it took care of the problem , before i adjusted it i didnt have much freeplay at all , so even when i put the clutch to the floor it wasnt fully disengaged which made it hard to get in gear it was like i had to really shove it into gear cause it would kinda be stuck on metal , after i adjusted it and gave it more free play it slides right in , if you have any more questions my AIM is tony101603 , i can tell you more about what i did
Old 02-17-2004, 02:28 AM
kjewer1 kjewer1 is offline
AF - Advisor
If the engagement point is low, then I would suspect clutch hydraulics (check them all anyway). If the engagement point is fine, it could be shyte fluid. But it would have to be pretty bad. I would physically check the slave (under the front motor mount) by pulling the boot back and looking for fluid leaking out. Check the master by looking at where the clutch pedal push rod goes into it, if its leaking you'll see fluid there and down the firewall. Bleed it as well. Change fluid just to have good fluid in there. 99% of poeple use BG synchroshift.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
2002 Santa Fe Transmission shifting problem BobandIngrid MY 01-06 0 05-14-2010 12:40 PM
f150 aod shifting problem barshowfamily F Series 2 11-30-2009 08:57 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
Auto Trans not shifting Fontenot74 Mustang Problem Diagnosis 2 03-04-2009 08:30 PM
