Old 02-16-2004, 06:53 AM
DOG214 DOG214 is offline
95 Boniville
Car Will Not Start After Being Parked For Two Days. V6 3800 Series. Has New Battery,no Lights,door Chime And When You Turn The Key All You Hear Is A Clicking Noise From Behind The Glove Compartment And Pass-air Bag. Any Ideas? Thanks
Old 02-16-2004, 05:17 PM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
If it doesnt even try to turn over it's something within the charging system or starter line, if you don't get any kind of door chime, domelight or anything like that the battery is dead. Check your fuses, both under the hood and inside the car first. You probably have some kind of constant drain thats killing the battery, or you just got a bad one.
Old 02-17-2004, 07:33 AM
Re: 95 Boniville
Thanks, I Found A Battery Cable I Need To Replace For Starters, Then I Will Check Out The Charging System,. I Still Have A Nagging Feeling That There Is Something Else, We Will See.
1988 Boniville code 41 bigbird0001 Bonneville 8 11-24-2012 10:57 PM
97 Boniville Engine warms up then hard to start hellah fresh Bonneville 1 07-07-2010 10:19 PM
1992 sse boniville electric climate control(ecc) bryankris Bonneville 4 07-29-2004 04:13 PM
