Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 02-16-2004, 02:25 AM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Installing Springs ?
I want to install some springs on my civic as soon as it gets here but I was wondering if its possible for me to install the springs in my garage with the help of a friend of mine, basically im asking if anything other than the regular tools are needed.
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 02-17-2004, 10:30 PM
BullShifter's Avatar
Re: Installing Springs ?
You need a spring compressor & alignment rack. I don't rec. using the cheap spring compressors from auto parts, seen 1 to many loaded springs take off - busted cement floors/walls. Read & follow directions, springs/struts/coilover(true or sleeve) are pretty easy to install *if no bolts are seized* When the lower control arm bolts are frozen you must cut bolt & press out bushing then press a new one in. Only use high grade bolts for suspension. SOAK THE SHIT out of all bolts to be removed, 24hrs or more, with penatrating oil(not WD40).
Need help with installing springs on my 2002 GTI millercj1976 GTI 0 01-24-2004 08:24 PM
installing springs and shocks blueturtle Tires and Wheels 2 06-21-2003 06:02 PM
Installing springs....should i do it myself or no Dark Syde Racer '88 - '91 Civic | CRX | Wagon | Shuttlee 14 11-01-2002 03:41 AM
Installing Springs Help WonderinAbout Tires and Wheels 5 09-03-2002 01:35 PM
installing springs Seneb Suspension 16 02-22-2002 02:00 AM
