Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-15-2004, 11:29 PM
skorpio1975 skorpio1975 is offline
Send a message via MSN to skorpio1975
De-supercharging ?
Can I drive a supercharged Buick with the belt off the supercharger? Is it going to be driveable? Can I damage something? Reason I want to do so is that I have a weird grind noise while driving and I would like to make sure that its not the SC that grinds.
Thank You for any help.
regards, Bart.
Old 02-22-2004, 09:18 PM
tooltimetech tooltimetech is offline
Re: De-supercharging ?
Yes it is driveable, I have seen them come into the shop with out a belt on the supercharger and the customer was not complaining about it. (And they didn't buy the idler pulley and belt to fix it.) They drove it away as it was.
19 years experience fixing cars.
Many more years experience taking them apart to see what makes them work.
ASE Automotive Service Master Certified
L1 Advanced Engine Performance Certified
ASE Engine Machinist Master Certified
GM Master Certified in 5 areas, more coming soon
Old 02-29-2004, 11:53 PM
Skavoovie Skavoovie is offline
You can run it without the belt. Performance will be decreased greatly, but it won't hurt anything.
As for grinding noises, the three most likey causes are:
1) Bad axle bearing(s). Common problem on Regal GS, probably on Park Ave. Ultra, too.
2) Old supercharger belt squeeking, though not really a grinding sound. Simply replace the belt to check; Autozone has a good return policy.
3) Bad supercharger snout. The expensive one. More common if you're running an aftermarket pulley. Could be caused by loss of/poorly maintained supercharger oil (the supercharger is lubricated by it's own oil), so check that.
Old 03-05-2004, 05:24 PM
Thank You for answers.
I have beed driving my car for a while now and I have realized that grinding sound comes when the car is tilted to the driver's side. It is enough to jack the car up on the passanger side, so I dont have to drive it for the grinding noise to show. I have just replaced the coupler because it was noisy and filled it with fresh oil. I am almost certain that it is the supercharger bearing. Not the one in the snout, but the one from the coolant side.
When Ill drop the belt, Ill be sure.
Once again, thank You for answers.
regards, Bart.
Un record de premières au Salon de l'auto de Los Angeles - GuideAuto.com Automotive News Automotive News Desk 0 01-07-2007 10:10 AM
Super HICAS de-act-de-va-tion??? friday86 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 10-09-2004 05:58 PM
recherche body de crx urgent de 88 a 91 civic24 '88 - '91 Civic | CRX | Wagon | Shuttlee 14 04-22-2003 12:10 AM
