Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-15-2004, 08:59 PM
AeroE AeroE is offline
Question Handling
chalk this one up to my inexperience, but i was wondering how a 240z's handling is compared to modern cars? and if you did drop in a SBC how would that effect your handling. i know that if you follow the JTR example the engine is pushed back a few inches closer to the firewall, meaning all your weight would be behind the front struts, but at the same time your adding 140 lbs.
what does all this equal out to??
Old 02-27-2004, 05:19 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
You add 100lbs to the front, and 40lbs to the rear of the car. If you use an all iron chevy block.
Aluminum Heads, Intake, water pump, other lightweight goodies will drop that weight down to about 85lbs gained.
When dropping the SBC into the S30 chassis you gain a 50/50 weight distribution. Datsun set the car up with a 51/49 distribution from the factory.
Just upgrade your suspension to like Tokico 5 way adjustible's, with springs and some urethane bushings. And some strut bars... and it'll hand better than stock. Infact, it'll down right embarass some modern cars.
Happy trails.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
