Old 02-15-2004, 08:23 PM
Phact's Avatar
Phact Phact is offline
Send a message via AIM to Phact
Junkyard Turbo Prices?? Would I need an engine build up??
Well i have a Jdm Zc. I want to run a junkyard turbo(i've heard go for 300-400 ranges for the hole package; hope its true). If so this is something i'm interested in but wont i also have to build up for the turbo? I have no clue how the turbo affects the zc with stock internals but i do not want to be blowing my motor anytime soon. Another question of mine is; i know that the intercooler for the dsm turbos are the little air filter looking ones i was wondering if you could upgrade an intercooler on just any turbo. for say an apexi intercooler greddy ish even just plain front mount intercooler. if possibly would it bring better results?
Outlines Questions From Above:
1. What are junkyard turbo average prices?
2. What would i need to make my motor ready for a junkyard turbo?
3. Can i upgrade intercooler and other parts on a junkyard Turbo?
My WebSite: PhactMusic.com GRAND OPENING!
Other Ride: 91 Honda Civic Hatch DX (Currently not running.)
It just had to dry dawg - DarkImportGrey
Old 02-15-2004, 08:28 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
I would say the real price of a junkyard setup is closer to $800-$1000, especially if it's your first time. Still, that's much much cheaper than a real kit.
If you ran low boost, (5-9psi) you won't have to worry about your motor blowing up.
You can upgrade anything off a junkyard setup. For an intercooler, you could grab an intercooler off a Starion, they are pretty big intercoolers and can be had for around $100.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-15-2004, 08:30 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: Junkyard Turbo Prices?? Would I need an engine build up??
1) I got mine for $200. Everything I needed except IC piping
2) If you will be running low boost, 5-8 psi you should be ok just tune it good. Anything over that you should think about some aftermarket internals.
3) You can use any IC. You run a charge pipe from your turbo to the IC so any IC will work.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 02-15-2004, 08:32 PM
check out www.honda-tech.com They usually have some people with good deals on turbo setups.
Old 02-15-2004, 10:02 PM
Phact's Avatar
Thanks, i tried that other site, havn't gotten much yet either but the replies are comming. any others?
Old 02-15-2004, 10:04 PM
AK_CRX AK_CRX is offline
You should be able to build one for $5-600 depending on how cheap stuff is at your local junkyard... You shouldnt pay more than $150 for a turbo, look for mitsu starions chrysler conquest, eagle talons, mitsu eclipse, Merkurs (rare australian built ford, comes with t3). shouldnt pay more than $50 for an eclipse side mount intercooler, shouldnt pay more than $30 for a 1g eclipse blow off valve. For piping, the cheapest route is to order two $25 cold air intakes for a 94+integra off ebay(integra cai has lots of bends) plus the intake on your car now will give you plenty of bends to cut up and put back together with some silicon connectors Get a used FMU to start you out, and start saving up for an Apexi AFC, and some mitsu turbo injectors. BTW, the side mount intercooler from an eclipse is plenty of intercooler for any streetable d series.
old setup: stock usdm B20b (8.8:1) tall LS gears, 14.3 @ 97mph
new setup: d16z6, a6 pistons, d16y7 head, si intake manifold, intake, exhaust, si ecu, apexi SAFC, Si tranny, (header, and delta 272 cam on the way)
www.ttuner.com
Old 02-15-2004, 10:55 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Man, you should hit up Jon @ http://www.thedropshop.tv
He's got a 4g Civic with a turbo'd ZC pushin' some nice hp...somethin' like almost 300hp to the wheels.
He's been there & done that and can probably help you out as much (if not more) than we can.
Old 02-15-2004, 11:58 PM
Phact's Avatar
What do i all need to make the turbo kit complete?
Old 02-16-2004, 01:14 AM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
you need a turbo manifold turbo down pipe piping for ic and ic to throttle body vaccum lines for wastegate blow off valve and you want a boost gauge to know that the wastegate is working (my friend didnt do this right now i own the car cuz i rebuilt it detonations a bitch) make sure your not going to be pushing 12 lbs on stock internals that should be about it
Old 02-16-2004, 01:57 AM
Phact's Avatar
Thanks a bunch man!!!!
any one else have anthing to add???
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
