Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-15-2004, 06:18 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
srt-4 stock psi??
how much boost(psi) does the srt-4 come with??
and also how much psi can a stock srt-4 hold on stock internals?
and is there a differance between the 03' and 04'? or did they even make a 03'??
civ eg hb/b18c1
PT61 .68ar p-trim
Full-race pro street manifold
Neptune EMS
412whp@10psi 11.62@118
633whp@28psi 10.45@135
Old 02-15-2004, 10:30 PM
Roscoe86 Roscoe86 is offline
Send a message via MSN to Roscoe86
Yes, they made an 03 SRT-4. the 03 had no LSD, smaller fuel injectors, Michelin Pilot Sports, and had a solar yellow but no electric blue. The 04 has an LSD, larger fuel injectors, electric blue paint but not solar yellow, and uses BF Goodrich tires. Not to mention 15 more horsepower. Stock, the SRT-4 comes with either 14 or 15psi, i've heard and read both, can't remember which is the right one. As far as how much boost the stock internals can take...well, the stage 2 turbo upgrade will boost the psi up to 20, the limit of the stock turbo. Also, the NHRA Summit Series SRT-4's use the stock block, head, and crankshaft, and you know those drag cars have got to be pushing in some serious boost. Any more questions?
Old 02-16-2004, 12:09 AM
got v-tec?'s Avatar
in about 2.4 years im selling my civic and getting a 2004 black srt-4 there bad ass!! by the way what size was the 20003 and 2004 injectors?
civ eg hb/b18c1
PT61 .68ar p-trim
Neptune EMS
Old 02-16-2004, 11:03 AM
03cavyTT 03cavyTT is offline
Re: srt-4 stock psi??
stock boost is 15 and drops to 11 after red line
Old 02-17-2004, 06:54 PM
camlifter camlifter is offline
stock i got 10 psi in 1st gear and 13 psi in the rest, stage one took it to 12 in 1st and 15 in the rest, stock injectors were 380cc and s1 are 550cc, the 04 basicly gets stage one stock with a lsd, the boost is also controled by the pcm for max tourqe, if the air is cold you make power easier so it takes out some boost, the hotter the incoming air is the more boost you get up to the limit the pcm alows, which is 15psi with stage 1
Old 02-17-2004, 08:25 PM
inzanesrt4 inzanesrt4 is offline
the wastegate in the SRT-4 has a 4 pond spring so after about 3,000rpms you loose about 3-4psi so if 1st you get 12psi it will drop to about 9-10 psi. the others 15psi drops to about 11-12psi. Internals can handle up to 20 psi as long as you get the right Air/fuel. probably more. One guy already is pushing 500HP on stock block but upgraded turbo.
Old 02-19-2004, 11:32 AM
where did you get these numbers at cause i have read stock 15 after redline drops to 11
Old 02-19-2004, 11:35 AM
Let me clear that up. I have read that the 04 comes stock with 15psi and after redline it drops to 11psi. I am wondering where you got your numbers from
Old 02-19-2004, 06:22 PM
12 in first and 15 in the rest, it does drop at red line which is 6k, rev limit is 6200, just shift a 6k and it won't drop off
Old 02-19-2004, 11:32 PM
I get these numbers from staring at the boost gauge of a car I've owned for almost a year now.
Redline is this:To reach the maximum engine speed at which an engine is designed to be safely operated:
Boost drops before redline. My Car and everyother SRT-4. I've talked to (over 200) start losing boost after about 3,000 rpms and only hold 11psi to redline not past. Also from 6000rpm to 6200 rpms is a blink of an eye. to see gauge drop 4 psi you would be over rev limiter.
Old 02-20-2004, 03:02 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
lets not forget that the psi varies greatly depending on atmospheric conditions and altitude since PVO designed it to have the same power in virtually any conditions.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 02-20-2004, 10:21 AM
Hey i am just tellin you what i have read no need to get all pissed off
Old 02-20-2004, 06:58 PM
I did not mean to sound pissed. I just read over my post and can see how that could be read that way. I was actually laughing while typing because My name says SRT4 as yours says Cavy so I assume you drive a cavy as I thought everyone would assume I drive a SRT4. Also In the past I have answered any questions youve had of SRT-4. I will say this a trick I'm not sure everyone knows but us first owners figured out was we can go to Home Depot or Auto parts store and get 10 pond spring hook it to waste gate arm and back to battery tie down And hold boost all the way to redline. It causes a little spike sometimes but no harm. I also know a few other tricks since this has been Dodge Turbo problem in past as well as some other manufactured turbo vehicles.
Old 02-20-2004, 07:11 PM
Neutrino's Avatar
Yaya Master
Re: Re: srt-4 stock psi??
Yes the infamous turbo dodge dollar mods.
I swear reading turbo dodge forums is like reading some MacGyver script. Chewing gum, a swiss army knife and a few househould cleaning producs and you're in the 11's.
Btw another good mod during the winter is to heat up the temp sensor so it will think its hot and push full boost.
(\__/)
Old 02-20-2004, 09:39 PM
Ya I like wrapping it with hand warmer. Its amazing that some things are so weird you think your the first to try it then you read about how it was done twenty years ago. I swear we just keep repeating time over and ove again. Nothing ever new someone just refined it or made it popular. Its like recipies that have been past down from family to family. One just might add more sugar or butter.
