questions
do the 90 though 97 cougars be on the same fox platfor if so can i switch parts. the reason im asking is i wanna gt rid of the shitty buttons on the drivers door. i also want to convert the front end and tailight to the 97 euro light. i also need a chrome luggage rack
Re: questions
in english please? do you have a fox body? is so, you can't swap anything from the 89-97 cougar and the following paragraph won't mean anything to ya. i mean i'm sure you could make things fit, but it would be time consuming and a lot of fabrication.
if you have an mn12 (89-97) and if you're talking about the exterior door handles, you can get 96/97 color coded door handles. and it is possible to swap the front end to a 96/97, but you'll need many parts, and you'll have to change headlight wiring harnesses to accomodate for the 2 bulb headlight system.
![]() 1996 Thunderbird LX 3.8L 1993 Thunderbird SC 3.8L 2000 Cherokee Sport 4.0L 2005 Tacoma X-Runner Jersey Rice NJ Thunderbird & Cougar Club |
Re: Re: questions
Re: questions
take the buttons out and fill the space. or you could swap doors, but that would be more of a pain.
Re: questions
i dont wanna fill the panel i just want the door. it needs bushings so i might as well swap it
Re: questions
any door from any mn12 will fit. but you probably want one from the same body style. i don't know the cougar body style break down, but i believe it's 89-95 that all shared the same body panels. in 96 they added the side cladding as seen on the thunderbirds.
Re: questions
i located a 90 without the number pad and in matching black. im not adding the cladding when i convert the front end. we have to measure upfirst to make sure it will clear the engine
Re: questions
if you swap to a 96/97 front bumper, you will have the molding line that flows from the side body panels. it's no big deal though. people swap to the later style front ends all the time and it looks fine.
and it will clear no problem. but you will need many parts. hood headlights corner lights front bumper cover the actual front bumper (the foam under the bumper cover) headlight wiring harness (to accomodate for the two bulb headlight system in the 96/97 lights) 96/97 header panel (what the headlights attach to) 96/97 hood release latch
Re: questions
i got a whole 97 front half we cut it in half for easier acess i made 1000 bucks off the engine
Re: questions
Is there any way to clear your stock headlights on a 99 cougar?? The reflectors look like they pop right out. Any ideas??
