Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-15-2004, 05:09 AM
kevinorhoades kevinorhoades is offline
? 2nd gen sunroof fix?
My sunroof is broken. One of the parts that held it to the car cracked, it got stuck mid track so I had to remove the thing, and basically go Tim Allen on the thing. I'm wondering how this works, am I supposed to remove the headliner to get to the frame and remove it from inside? I don't really care if I get the sunroof to function, I just want it to sit on there right, make the vehichle secure, and keep the weather out. What baffled me when I was "removing" (demolishing) it was that there were screws that i could see that were impossible to get to. This is why I presume the whole thing can be removed from the inside, but I don't want to bother removing the headliner if that's not the case. Is there somewhere on the internet where I could find a how to on this job? My car kind of looks like a p.o.s. with the sunroof sitting crooked on there, held in place with packing tape.
Old 02-15-2004, 11:18 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Re: ? 2nd gen sunroof fix?
Pop off the fuzzy headliner button/cap, stick in the right size allen wrench and turn it till it's closed. I suppose you didn't get the SST wrench?
Old 02-16-2004, 12:54 AM
The motor didn't die, the link between the roof and the motor was broke, and one of the brackets that secure the roof was broke. I tried turning the crank before I took it apart and it did nothing.
Old 02-16-2004, 10:07 AM
Yea, then you have to remove everything, all windsheild trim peices, the B piller panels, headliner, sunvisors, all that stuff to get to the sunroof. If you want to take it out theres just 4 bolts on the corners holding it in, just make sure you undo all the harnesses and hoses first.
Old 02-17-2004, 12:42 AM
Ok. I was afraid the whole thing would be welded in there.
