1992 cherokee stalls
My jeep has been stalling running down the road and will normally start right back up. Sometimes takes a while to restart. When it happens the tach just drops out and most times put in neutral and will start back up. Happened yesterday a short ride to the store from a cold start and was hard to restart and did not want to run and died three times on the way home and was hard to start each time and was cutting out. Bought a new fuel filter today have not installed yet checked fuel pressure around 35 pounds at idle and 42 at around 2500 rpms. Checked computer got a 32 then a 55 reading my manuel did not have 32 code and said 55 was showing end of code. Any help would be great I'm lost on what is wrong.
A 32 is you EGR Valve being either stuck open or closed. If the EGR valve is not functioning properly then it will cause you engine to surge or stall.
Re: 1992 cherokee stalls
Re: Re: 1992 cherokee stalls
The leak from the filter mount is a VERY common prob on old 4.0L engines. Its just an o-ring thats old and has rotted. A new o-ring set should only cost ~$10 and you can only get them from a MOPAR dealer, like your Jeep dealer for example or any other OE MOPAR Parts supplier. Its a very easy fix.
The mount is just one bolt. Take off the mount and replace the big o-ring. When I bought the o-ring set I got 3 rings but I only needed one so if you cannot find out where the other two go when you fix it don't sweat it. Also, coat the ring in a thick grease to ensure it doesn't get dry and rott out ever again.
Your EGR might be an intermittent problem. If it doesn't flash it again and your drivabilty problem never comes up again then your ecu must have flashed an incorrect code for whatever reason. The sensor in the distrubutor is the cam position sensor and you shouldn't need to pull the dizzy to get it out. The crank position sensor is on the bellhousing located behind the intake mainifold.
I may have missed soemthing...are you talking about the oil filter mount? or some other filter? Let me know...I have a oil drip on my 94 i've been trying to fix and it still seems to be there only very very small now. If i can ever get it fixed I can park in the driveway again! :-)
John Harris http://www.electra225.com "Problems are just solutions in work clothes" |
If you feel the leak around your oil filter mount then the filter mount is the source. Your front and or rear main seals could be leaking as well.
yup i was thinking it may be the rear seal as the leak drips right down the back of the oil pan and off the drain bolt...thanks!
Re: Re: Re: 1992 cherokee stalls
Does anybody know where the location of the oil sending unit sensor is located on a 89 inline 6 4.0L? PLEASE HELP
