Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-15-2004, 03:16 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
clutch problem
ive had a problem with something the past few weeks.i get a bad rattling when starting(stopped) out from 1st gear. when i engage clutch it seems to slip a bit(while rattling) then after clutch is engaged its fine. only does it when starting out when completly stopped. also does it when i go reverse. i have to ride the clutch in order for it not to rattle. clutch is pretty new too. someone told me it might be some teeth are messed up. anyone have an idea of what could be causing this?
Old 02-15-2004, 09:58 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: clutch problem
You need a new clutch, sounds like the pressure plate is not clamping down on the clutch disc right. You should fix this soon.
