Old 01-01-2002, 12:38 PM
RickDaTuner's Avatar
RickDaTuner RickDaTuner is offline
Spiking Revs
I have been @ this problem for qiute some time now I start my car and let it warm up once i'm out driving a round I'll get a boggin feeling when coasting not when I'm accelerating nad when I Idle the car the revs startr to spike like from 800rpm up to 2500 I,ve checked the distributor rotor and what not all seem to be in right working order
(minimal corrosion) I had the spak plug wires check and they came out with close to nothing resistance I had just changed the spark plugs and gapped them correctly. I later then took my fuel pump out and bench tested it no prop, i also took out my injectors and cleaned them by hand none of theses things did anything for my car mabey Fritz or Moppie can help me out on this one
oh yeah (92 Civic VX )
Old 01-01-2002, 07:20 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Its a disconected or worn/broken vacume hose.
You'll have to go over every one by hand untill you can find it, then get it replaced.
Old 01-01-2002, 08:52 PM
see I though it would end up being something like that i'll check them out thanks
Old 01-02-2002, 05:25 PM
praxis praxis is offline
I had a similar problem...along with smoke (after about 2 weeks of still driving it)...it was the head gasket. If all else fails check that out. If you're not getting the smoke and antifreeze smell (through the vents), I doubt that this is your problem...but who knows...it could just be minor right now.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
shift into rev kills engine with rev light sickflatback '88 - '91 Civic | CRX | Wagon | Shuttlee 14 12-22-2005 09:23 PM
HIgh rev idle and bucking at high revs UnWanTeD S-10 3 12-14-2004 10:08 PM
shifting at higher revs, better than at lower revs ?? 96LSIntegraRocket Engineering/ Technical 9 05-03-2002 12:53 PM
Boost spikes Ammi MR2/MR-S 1 11-20-2001 01:53 PM
spike spike Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 05-07-2001 06:30 PM
