Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-14-2004, 07:11 PM
jimmyhf6 jimmyhf6 is offline
wat kind of turbo is there 4 a 240sx
i dont no much about nissan turbo i was just wondering wats like the best and worst and the ok ones thanks for replys
Old 02-14-2004, 10:35 PM
terifi's Avatar
terifi terifi is offline
Re: wat kind of turbo is there 4 a 240sx
beats me as far as best to worst, try some searching around and perhaps you can find the specifics you want to compare as far as sizes/psi/etc
some companies make kits like Greddy, Fmax, they usually run around 3-4 grand and if you dont know that much as far as turbos go, this would be a good Noob idea, but if you want the bang for your buck and/or your willing to get your hands dirty (or pay someone else to)...i would go with seperate parts, more customization, better tuning, and better performance
just my 2 cents
Black 96' 240sx SE, 266k and running like a champ
Old 02-15-2004, 08:49 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: wat kind of turbo is there 4 a 240sx
well it depends if you want to use the ka24 motor or the sr20det motor b/c the ka can support a bigger turbo b/c it has more liters so it will be able to spool up a bigger turbo at the same rpmz as a sr... for any 4cld motor i wouldnt get a turbo bigger then a .72 a/r even .72 wil be hard to spool if you motor is stock, for stock internals i say get a turbo that has a .65 a/r to .67 a/r that will spool good and give you decent top end. also you might want to look into the flow of the turbos you mihg want one that flows 400lb/min that will make about 400hp for you..
goos luck
1
Shift_BOOST
97 s14
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
