Old 02-14-2004, 04:22 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Aftermarket intake manifold question
So I'm looking into getting an intake manifold for the old b16, and so far Skunk2 looks good. My only problem is that they are only offering the intake manifold for OBD1 or OBD2 b16's. Is there a way to make them work with my OBD0 b16?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 02-14-2004, 07:00 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: Aftermarket intake manifold question
I would have to recommend the "typhoon" manifold, I have seen great reviews for it, and it is only about $150. Works for OBD1 too.
It is styled after the type-R mani, with a slightly longer plenumn for better distrobution to cylinder 1.
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 02-14-2004, 09:17 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
I had planned on using the ITR intake manifold. Supposedly the plenums are a bit bigger and the manifold itself is supposed to flow better than the stock B16. Not to mention it's relatively inexpensive.
I've known people who used the JG manifold as well as the Skunk2 manifold. They're both really happy with the resulting gains.
Old 02-15-2004, 02:45 AM
GVR-4&a90Si GVR-4&a90Si is offline
I saw in the last issue of Sport Compact Car that BBK has a new manifold for the B series. It was hot. Gunmetal color, kind of a blend between a Venom and a Skunk2. (round plenum w/ short runners) and it will accept a 70mm t/b. approx $250.
Old 02-15-2004, 04:39 AM
Marc-OS's Avatar
How do you make an OBD1/2 manifold work on an OBD0 car though?
20 GOTO 10
RUN
Old 02-15-2004, 10:43 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
bolt it on. and use different length vacuum lines
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
