| Off-Topic Talk about anything other than cars. |
6-bolt 4G63 Turbo/NT swap question
I am looking into doing the 1G swap into my GST. Can i buy an NT motor and swap my turbo/ intake/ exhaust etc onto it and end up with the same motor? NT engines are way cheaper than the turbo ones.
97 GSTBoy 1997 Eclipse GS-T 5 spd Bone Stock baby! ![]() DUH! of course not by choice.
No. The NT motor is a 420A
For Sale 98 Eclipse GS, 5 spd |
Not all of them.
sorry... i didn't see the 1 gen.
I thought you were talking about 2nd gen.
no problem. got myself a case of crankwalk and i'm trying to do the 6-bolt swap. just need to know if i can get the NT engine and put my turbo parts on it.
the N/T 4G63 internals are different.
i know its got bigger rods and a 6-bolt crank, i guess i'm asking if i can just bolt up my stock 2G turbo setup to it and roll. or are there other mods that need to be done to make the swap work?
who says it as bigger rods?
a 1G turbo does, but the N/T also? u need to look into that what about the pistons, the obviosly wont have the same 7.8:1 pistons and the 4G63T |
ah yes, good point. i will have to check it out...if that is the case i will have to crank up the turbo or get a bigger one to keep the same # of horses in the corral. i guess i'm not worried so much about the inside of the engine, but more on how it will bolt in, and whether it will bolt up to my turbo/intake/exhaust.
Re: 6-bolt 4G63 Turbo/NT swap question
FourG hit the nail on the head. You do NOT want a NT block, for the high compression ratio and weaker pistons. The turbo 90-92 6 bolt motors have the big rods. You can use the later 1g 7 bolt turbo motor, but it wont be an upgrade for power handling, and they do occassionaly CW, though less often than the 2g 7 bolts do. They will swap in the same. Read the tech article on www.magnusmotorsports.com. Everything I need to do these swaps is in there. But the bulk of it is modifying the 2g timing belt side motor mount to clear the 1g pump, and wiring in the 1g CAS to get crank/cam angle signals to the ECU (the 1g head and block do not have provisions for the 2g sensors). RRE has instructions and wiring diagrams, and I think magnus just links to those. The rest is getting together all of the parts you need. The list is on that site.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
what about rebuilding the bottom end with a new 6-bolt crank/flywheel and some good aftermarket rods pistons? if the top end is good do i need a whole new engine?
engine, tranny
If u really want to then try to build up the NT, but the turbo version, can handle 350hp all day long, and some can goes to 400 to 450, before rebuild with stronger part, building the NT is a waste of time, and money. U can pick up a cyclone with turbo about 1200 to 1300, with awd tranny 1800. is not a bad deal at all. i got other question, i got 90 6 bolt do anyone knows that 2g tranny can fit??, or have to be 1g. any info help please
this is old
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
yeah, i noticed, oh well.
Re: engine, tranny
